SNECMA Colibri (that's 'Hummingbird' in French....)
Started by PR19_Kit, February 07, 2013, 01:45:53 PM
Interesting find Kit  :thumbsup: and those missiles look like very early Sparrows
Quote from: kitnut617 on November 07, 2019, 09:17:45 AM
They're pretty big, aren't they?
Probably a French equivalent to a Sparrow, but there's no obvious radar set for the missiles to 'ride in' on as far as I can see. The only other French missile I know is the Matra 430, but that's a short, stubby thing. I did think of using a couple of them on the Colibri but they're far too wide.
As is almost normal for me at this time of year almost every non-sleeping hour is spent on or near my model bench!  :banghead:
At LAST I bent and glued the last bit of wire for the steps on the erector/launcher and rapidly applied a coat of primer. Colour coat, only one of them, goes on later this morning. The aircraft bit has had it's last paint details added and a coat of Klear applied, and the very few decals will be applied in an hour or so.
And then I'll just have enough time to tidy the place up a bit before I head off north toward my youngest daughter's place before Telford tomorrow. (Did you know she was the RAF's Best Air...................................oh, you did. OK.)
Quote from: zenrat on November 07, 2019, 03:23:57 AM
Quote from: PR19_Kit on November 06, 2019, 04:38:59 AM
Just a few Magic missiles to arm the Colibri..............  ;D
Two of the Magics have a more pointed nose.  I think they are the two I sent Kit from the Academy Super Etendard.  Now that could be Academy representing a different type of Magic (radar as opposed to heat seeker - or vice versa) or it could just be Academy not getting it quite right.
I think the latter - as far as I know, there is no radar version of the R550 Magic.
Quote from: Weaver on November 08, 2019, 12:42:15 AM
But this is WhiffWorld...................  ;) ;D
Maybe they truely are magic and there is an imp in the nose steering the thing and a small dragon at the back providing the thrust?
<_<
Quote from: zenrat on November 08, 2019, 02:03:52 AM
<_<
They're French so ANYthing is possible.  ;)
Quote from: PR19_Kit on November 08, 2019, 01:53:53 AM
Congratulations Kit for this dreamy state of mind, I approve that, thanks! :thumbsup:
And here's the airborne part of the model done and dusted.
The paint on the erector/launcher is still drying...............
It is funny that, contrary to your siganture word "Any aircraft can be improved by fitting longer wings", this model has a tiny span... ;D
But maybe this was the reason for its not being ordered into mass production. :unsure:
Could you fit some missiles inside the lower part of the wing?
Quote from: zenrat on November 08, 2019, 03:12:33 AM
Believe me, if I could get in there I would have.  ;D
It was difficult enough PAINTING the inside, let alone gluing bits in there.
And here's the whole shebang, with the varnish on the erector/launcher not exactly dry, but what the hell.  ;D
Well indeed, and there was an SARH version of the Sidewinder (AIM-9C). It wasn't very good, but there's nothing that stops the French from copying a bad idea...
For the backstory, remember that, in the real world, the Magic didn't enter service until 1976.
It looks great Kit - begging for a diorama base (not before tomorrow though...). :thumbsup:
