avatar_Draken35
"What-if" : Messerschmitt P1099B (Revell 1/72)
Started by Draken35, January 20, 2013, 03:39:32 AM
Draken35
I'm just starting this one...
I will not build a "Luftwaffe '46"; I have a different idea. More infos later (keep a little bit of suspense...)
Nice kit anyway.
First; holes for the rear machineguns are drilled
...Then, those of the front guns
Wings are glued (Very Me 262-like)
For the code of the aircraft, I will use home-made ones: decadry letters and numbers on clear decal sheet. I will have to add liquid decal film from Microscale
More progress soon I hope...
matrixone
Looking good so far...I am building one of those too.
In your third pic with the drilled out gun openings, are you sure this part is to be used with this varient? My kit came with two of those parts, one with the guns like in your pic and another minus the guns.
But since this is a what-if its not all that important anyway. ;)
Matrixone
I picked this up in the Modelzone sale, be interested to see what you do with it
Judging by the letters, I'm guessing it's going to be a Czech one.  Hmmn, like that idea...
Yup, looking good so far ! Not a big Luft '46 guy, but those Revell kits are so nice I've been buying them..... :thumbsup:
Yes....!!!! The little things count....!!! Drilled gun barrels....! Love it...👍 looking forward to the finished article.....
Interesting. :thumbsup: Will you have a classical Me-262 to display with it?
Draken35
As MAtrixone said, the part I have drilled is the one for the 1099A (monoplace)... Will not be used, simply.
All the parts are actually removed from sprue...
Canopy is masked
Well, ready for painting
(if you are attentive, you can see what country will be represented...)
The aircraft will not be displayed with a Me262 but I'm thinking to a little dio...
Slerski
« Le MAGIC, c'est fantastique !! » [Sgt Vincent D., FAF armourer]
« Un Pétaf qui s'ennuie est un Pétaf dangereux... »
Draken35
I'm back...
As said, not a German; so I will not use any RLM paint...
Gunze H312
Draken35
Cockpit painting. Some touches of colors, because the cockpit is large...
Draken35
Now I use bottle/jar tops to mix paint in but never thought of using them as "handles" - thanks for the idea
