avatar_MartG
1/144 NASA SLS Block 1
Started by MartG, October 30, 2012, 07:10:55 AM
MartG
I guess this just about qualifies as a whiff - as in what if it doesn't get cancelled  :rolleyes:
My latest resin creation, the Block 1 version of the Space Launch System. The kit is based on the Block 1 SLS-1000X configuration from the 'Space launch System Program Launch Vehicle Specification' document issued by NASA 26th Jan 2012, and uses a stretched version of the Shuttle External Tank as its core stage, with four RS-25 SSME engines and two 5-segment boosters. I've painted it in the black/white scheme shown in the NASA publicity material, though I suspect that after the first couple of flights it will probably revert to the bare orange/brown insulation seen on the Shuttle tank.
The resin parts
A few pics next to my DIRECT Jupiter J-130 to show relative size ( the SLS is 650mm high )
I'm also building the Block 0 version, with a standard length tank core and 4-segment boosters - though it is unlikely that this version will ever be built by NASA.
Next on the workbench is the cancelled Constellation launchers, Ares 1, Ares V ( big ! ), and Ares IV ( Ares V with Ares 1 upper stage )
Cheers
Martin
Murphy's 1st Law - An object at rest will be in the wrong place
Murphy's 2nd Law - An object in motion will be going in the wrong direction
Murphy's 3rd Law - For every action, there is an equal and opposite malfunction
Goodness!  :o
And you moulded all those bits yourself? No 'kit parts' at all?
MartG
Quote from: PR19_Kit on October 30, 2012, 07:20:54 AM
Yup - all home made ( and copies for sale - see www.martins-models.co.uk  ;) )
Blimey Martin, you must have bought up a complete productiion run of Airfix Saturn kits to build that lot!  :o
And your WhatIf aircraft gallery is magnificent, you really should post some pics on here as they are right up our street. In the meanwhile, the rest of us should follow Martin's link to his homepage and look at hos 'Whatf Model Galery', WELL recommnded!  :thumbsup:
Interesting build. You're building up quite an extensive collection of rocket projects  ;D
Are you going to be at SMW?
Kit, they have been posted here!  Some of them look quite familiar.
Quote from: The Wooksta! on October 30, 2012, 09:48:44 AM
Must have been before I joined the Forum then.
I laughed like a drain over Martin's EB-66 as that's EXACTLY what I produced by accident a couple of years back when looking for a space to spot a Hawkeye radome!  ;D ;)
MartG
Just to add some pics now I've finished the Block 0 version too.
Lineup of three DIRECT Jupiters ( J-130, J-246, and J-246 Heavy ), SLS Block 0, SLS Block 1, and a Saturn V and Saturn 1 to show relative size
Block 0 with the alternative standard length cargo payload shroud
And with the long shroud
