Blasted instructions!
Started by rickshaw, March 27, 2012, 02:26:42 AM
Why do they have to print them so bloody small and cluttered?    :banghead:
Blame the company accountants, it's all down to 'maximising profits' these days.  :banghead:
Last time I think, I build a Revell Armour Kit.   :banghead:
If you have a scanner try printing them at high resolution and then printing them larger. You shouldn't have to go to that expense, but it's one possible solution.
Hadn't thought of that.  Too late now but something to consider for the future.  Good idea that one!   :thumbsup:
TallEng
Actually if its Revell and Fairly recent, they normally have them as an PDF to down load, So you could print
or even display them on your Desktop/Laptop and enlarge to your hearts content.
Keith
Ed S
Instructions?  This is WHIFF land, why would you look at the instructions?
:party:
Ed
puddingwrestler
Instructions are for the weak! Throw them away and just make it up as you go along, you will find yourself a happier modeller, and avoid the dreaded JMN syndrome!
RussC
#8
Instructions = cat box liners  :lol:
Seriously, when taking some of my graphic design courses a few years back, I used some kit instructions for "Show us the worst informational pages you have found" assignments. Bad drawings, bad typography and yes, layout problems up the w@zoo.
I defy someone to put together the Revel Boxer APC's suspension without the instructions and have it turn out OK.  Even with them, it is a challenge that has nearly defeated me.    :rolleyes: :banghead:
puddingwrestler
All 1/76 and 1/72 armour components smaller than a hull should be regarded as detailing greeblies for SF projects. They defy construction as anything else in my experience.
Joe CalPo
Yes, avoid using the instructions so you can forget to mount the main gun in your German SPG before putting the hull together.
:banghead:
Fortunately it came back apart without too many cracks.
Blowing up the instructions doesn't help when there are too many parts crammed into a picture with little lines criss-crossing and not really reaching the actual parts or final locations.  :-\
