Author Topic: WHIF's found in Magazines/books  (Read 50983 times)
Offline scooter
Re: WHIF's found in Magazines/books
« Reply #195 on: February 20, 2019, 06:10:52 am »
Looks like the XC-142A (not the best photos from the old NMUSAF Experimental and Presidental Aircraft annex)
(Behind Rutan's Pulse-jet thing, with horizontal rotor visible)
Oh are you from Wales ?? Do you know a fella named Jonah ?? He used to live in whales for a while.
Offline Tophe
    • my what-if models
« Reply #196 on: February 20, 2019, 06:14:42 am »
Thanks!
Offline zenrat
« Reply #197 on: February 21, 2019, 04:03:57 am »
I found this VTOL cargo with tiltwing in an old French comics, is this a XC-142 or imagination?
Nice.  I'd like to build something like that but the wing tilt would have to be working so it'd take a bit of engineering to do properly.
How do I calculate lifting capacity based on engine horsepower and propeller size?
Maybe just go with the "if it looks right it is right" principle.
Offline Tophe
    • my what-if models
« Reply #198 on: February 21, 2019, 04:09:15 am »
I wish you could do it. :thumbsup:
Don't be afraid: I will not argue that the propeller diameter is not perfect or something, as we are what-ifers, and a secret change in properties may explain all, what-if? ;D
Offline scooter
« Reply #199 on: February 21, 2019, 05:04:02 am »
Or look at what Vought/LTV did here
The C-142 was powered by four General Electric T64 turboshaft engines cross-linked on a common driveshaft, which eliminated engine-out asymmetric thrust problems during V/STOL operations, to drive four 15.5-foot (4.7 m) Hamilton Standard fiberglass propellers. Compared to conventional designs it was overpowered: it had 0.27 hp/lb, compared to 0.12 hp/lb for the contemporary Lockheed C-130D Hercules. This extra power was required for safe VTOL operations, and gave the aircraft excellent all-around performance which included a maximum speed of over 400 mph (640 km/h), making it one of the fastest VTOL transport aircraft of the era.
Offline zenrat
« Reply #200 on: February 21, 2019, 08:45:01 pm »
Thanks Scoot.
Offline joncarrfarrelly
  • Bertie Bassett
  • What-IF SIG
  • Turn that Gila-copter down!
« Reply #201 on: February 22, 2019, 09:42:37 am »
“Conspiracy theory’s got to be simple.
Sense doesn’t come into it. People are
more scared of how complicated crap
actually is than they ever are about
whatever’s supposed to be behind the
conspiracy.”
-The Peripheral, William Gibson 2014
Offline Tophe
    • my what-if models
« Reply #202 on: February 22, 2019, 10:37:01 am »
Thanks for this link, including the Canadair CL-43 twin-boom project 3-view, rare! :thumbsup:
Offline zenrat
« Reply #203 on: February 22, 2019, 04:20:40 pm »
Thanks Jon.  The tilt wing concept may be the answer to the question "how do I whiff this Airfix Skyvan?"
<edit> Just skimmed the file you linked to.  Excellent! Lots of whiffsperation there.  I haven't yet built a tilt wing with props so that'll be first but i'd like to revisit the tilt fan concept sometime.  I need to keep an eye out for suitable sized fans as scratchbilding them is very time consuming.  Computer cooling fans maybe?
« Last Edit: February 22, 2019, 04:24:30 pm by zenrat »
Offline Rick Lowe
« Reply #204 on: February 23, 2019, 12:09:49 am »
If you do find something suitable and Cheap!, can you please let the rest of us know?
I for one have a couple of ideas but I'm put off by the thought of scratchbuilding Two! engines with Contra-rotating! fans...  :banghead: :
Oh, and did I mention they are to be Shrouded?!  :banghead: :banghead:
Offline zenrat
« Reply #205 on: February 23, 2019, 12:19:59 am »
Oh, and did I mention they are to be Shrouded?!  :banghead: :anghead:
Yes. Cheap is the operative word here.  I'm sure I could find computer fans that looked perfect but then would have to junk the motors and casings which would be wasteful and expensive.
Offline Rick Lowe
« Reply #206 on: February 23, 2019, 12:39:54 am »
150% agree!
...well, maths was never my strong suit...  ;D
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #207 on: February 23, 2019, 12:42:36 am »
Perhaps using the fans from old and non-working PCs could be a solution? At the last count I have at least four large size PCs knocking about the place, and there must be a few fans in there.
Garden sheds, attics and basements all over the world could be a suitable source.  ;D
Online NARSES2
  • Global Moderator
« Reply #208 on: February 23, 2019, 01:55:34 am »
Must admit I've been musing on the idea of an RAF tiltwing transport for the GB
Decals my @r$e!
  • Bertie Bassett
  • What-IF SIG
« Reply #209 on: February 23, 2019, 03:12:22 pm »
https://www.ebay.com.au/itm/Mini-3-Pin-40mm-PC-Computer-CPU-Cooler-Cooling-Fan-40x40x10mm-DC-12V-9-Blades-/221339558322
4 or more for AU $3.22/ea
conspiracy.”
