avatar_albeback
A few weeks ago I had this mad idea......
Started by albeback, November 18, 2011, 02:16:46 AM
albeback
....... about a sort of super extended , tandem winged VC-10!! :blink: :blink:
Well, just to show I wasn't joking - here it is!. Not quite finished. Paintwork needs tidying up and, a coat of matt varnish but, to all intents and purposes, it's finished!
I can't be bothered concocting a background story so, I'll just leave to others to comment/advise/suggest/denigrate/laugh at as they think fit! ;D I definitely did NOT want another boring lo-vis grey finish so, I went retro with the camouflage!!
Doubtless I will have put many JMN noses out of joint with this one!! ;D
For the record, I used Xtracrylix XA1002 RAF Dark Earth/ Xtracrylix XA1009 RAF Mid Stone for the camouflage. All painting was done the proper, old fashioned way - with a paintbrush!! ;D.  I don't own an airbrush. No masking was involved in the demarcation between the Stone/Earth pattern. The Dark Earth pattern was drawn freehand with a soft pencil on the model & then painted with a flat 4mm brush.
Will be happy to answer any questions
Allan
IMG]http://i1098.photobucket.com/albums/g362/albeback52/009-4-1.jpg[/IMG]
INTERESTING.  :blink:
Do I detect over wing engine pods on the front wings,
something extending from the TE of the rear wing,
and
Brown Bomber camoflage?
albeback
Quote from: JayBee on November 18, 2011, 02:20:23 AM
and
Your eyes do not decieve you Sir!
These colours were applied to RAF transports in the 60s & early 70s. I rather like the finish. Much nicer than these boring lo visibility greys!
Now that really IS off the wall!  :thumbsup:
To be truly in the 60s 'Brown Bomber' scheme it needs a white patch over the cockpit though, like this :-
albeback
Quote from: PR19_Kit on November 18, 2011, 03:29:05 AM
Not forgotten!
I intend to use white decal sheet to provide the patch on the cockpit roof!
Aircav
That would look great in any colour scheme, Gerry Anderson would be proud of you.  :thumbsup: :wub: :wub:
Sir Sydney Camm
Vertical Airscrew SIG Leader
RussC
Quote from: albeback on November 18, 2011, 02:16:46 AM
Allan
  The noses out off joint is a desired consequence. We can probably never generate enough ire to dislodge the rectal stick though.... :lol:
  I like this design, and second the G. Anderson comment. I might have added a long wingtip (or 90 percent of the way to the wingtip) fuel tank joining the front and rear wings, am a turbulence worrier about those separate wingtips twisting the CG.
albeback
Quote from: RussC on November 18, 2011, 05:36:21 AM
Allan
The late Mr Anderson was certainly a source of inspiration! :smiley:
That's an interesting idea about wingtip fuel tanks joining the wing tips. Wouldnt be difficult to achieve. Thanks for the suggestion. I think I might just do that! :smiley:
lenny100
think th tip tanks would be a good final touch to a briliant idea
i like the way your thinking, great idea  :thumbsup:
Quote from: albeback on November 18, 2011, 05:43:02 AM
i believe ol' Gerry is still very wel alive and kickin  ;)
sideshowbob9
Yeah, get a bit of a Zero-X vibe looking at that. Great idea and model!  :thumbsup:
RussC
Pablo1965
Mad Idea? It´s one of the most interestig biplanes I ever seen,  :thumbsup: :bow: :bow: :bow: :bow: :bow:
Ah, maybe I would have placed one of the wings as the plane above, and another as inferior, but that does not matter
The Big Gimper
Excellent idea and build.
The Hood will most certainly attempt to hijack or else blow up this aircraft on it's maiden flight.
FAB.
Work In Progress ::
Lots of stuff
