avatar_McColm
Lockheed P-2V Neptune tanker conversion & alternative engines
Started by McColm, February 28, 2011, 03:47:48 AM
Hi,
Although this might not seem a new idea, my research shows that the Neptune was never used as a buddy-refueling aircraft or tanker to refuel other aircraft.
A civilian transport version was proposed but was cancelled. Although a few were converted for private use.
Nor was there an all jet powered version.
Cargo versions, AEW, MPA, bomber, night bomber, attack, trainer, Covert Operations, ElINT, Search and Rescue and fire fighting, with skis and even rato pods fitted,recon,drone mothership, carrier trials to name but a few.
My version the K would have all its bulges removed, a deeper weapons bay similar to the Ariel tanker/water bomber. I could use the refueling tanks off the C-130 under the wings. An old Airfix F-27 could be utilised, engines donated making it a turboprop.
Radical redesign in using Canberra engines or the jet pods off an old S-3B Viking. Thought of using engines off my wrapt Novo Shackleton if they fit.
No paint or colour scheme as yet, open to ideas.
The Japanese built a turbo-prop version, the P-2J, which was used for ELINT and drone control as well as the standard maritime patrol role. http://en.wikipedia.org/wiki/Kawasaki_P-2J
Love the idea. The Neptune is one of the coolest looking aeroplanes out there, and one of the most under-whiffed ! I've got three in the stash that were going to be real-world RCAF jobs....
Too bad nobody makes a 72nd scale DHC Buffalo, the engines from it would be perfect for that turbo conversion.
The Big Gimper
Quote from: Captain Canada on March 07, 2011, 11:36:39 AM
CC: How is your Portuguese?  ;)
http://www.commerce-center.com.br/produtofull.php?cartID=dc70c5852dfa58f55acea3cd92eea981&prod_id=3050015
http://www.whatifmodelers.com/index.php?action=printpage;topic=11268.0
Work In Progress ::
Lots of stuff
Todd , there are two companies that do a 1/72 Buffalo, Combat Models have a vacuform (I have one which doesn't look quite as bad as what Barry says) and then there's a Brazilian company that does a resin one.  I've seen one of those at Invader Hobbies in Calgary and the general concensus was "it was a piece of crap"
But there's this conversion to do a turbo-prop Neptune.
http://nsf.tc/~nmc/ProductDetail.php?iProduct=5&stock=0
Neptune wouldn't make a particularly good tanker aircraft.  The fuselage is too slim and it wouldn't be able to carry very much fuel.   Yes, RR Darts, even Tynes would more than likely fit.
Thanks,
I've seen the areial fire fighter version of the Neptune, they seem to have a deeper and squarer/oblong weapon bay. I was looking to copy that.
Has anyone thought of a four engine turbo prop version? Or all four engines being of the same kind on the Neptune, shortened B-17 in appearance?
Hi,
I've used two Allison T56-A-15 engines from Flighpath 1/72 resin set-djparkins. I carefully cut the engine cowling holes the same shape as the Allison engines. By inserting them the shape of the cowling changes towards the front end, but doesn't disort the backend too much.
I'm thinking along the terms of the Neptune MR2 for the RAF. Using ESM pods from the BAe Nimrod on the wing tips (if they aren't too long), instead of the searchlight and tip-tank. I'll also use the IR from the Nimrod and locate this under the Neptune's nose.
Another idea is to use the radome from my failed attempt of the Shackleton AEW-wrapt Novo kit and use this on the upper fuselage over the gun turret. I could utilse the missile racks from my Revell Tornado GR1 kit along with the seats, buddy refueling pod and inflight refueling probe. As the roof isn't flat the probe would have to be on the left or right handside of the fuselage.
I tentatively plan to use a couple of AS Pythons (i.e. Wyvern nose sections) to make an early updated RAF version.
Hi Guys,
What about an all jet powered Neptune, any suggestions on the engines?
Quote from: McColm on November 01, 2014, 12:23:24 PM
Hi Guys,
4 J47s, like on the B-45?
