Main Menu
avatar_Gondor
SEAC Meteor F2
Started by Gondor, February 13, 2011, 10:12:43 AM
Brush or spray, it doesn't matter. It's the colour that's the problem - Silver WILL highlight any flaws.
3 colour disruptive is ideal for hiding flaws.
Quote from: The Wooksta! on March 19, 2011, 12:50:11 PM
Amen, Brother! ;D
OK, three colour cammo it is then, unless I get a fantastic finish after the PSR work.
Started the next round of PSR on the underside of the engines. I will leave the upper surface of the wings and the top of the intake untill I finish the underside of the engines. I will have to do some work on the wheel well fairings on the undersides later as some of my sanding has altered the shapes a little  :banghead:
The amount of filler I had to apply was not as much as I thought. There are some flaws that I know of which I am willing to live with. Next for me today is to do more work in the cockpit so I can put the fuselage halves together.
The hole behind the cockpit- leave it until after the fuselage is glued together, then use some thin plastic card and mould it into the fuselage up to the back of the resin bit.  Add filler on top and sand flat.  This will also give a basis to get some decent sied lumps of lead into the fuselage to weight the front end down.
Thanks for the tip about shaping the area behind the cockpit Lee, I had already thought about the weight going in that area though.
It's the only place where you can get enough lead in.
Found out last night that I may have to rebuild the engines as they are not identicaly placed  :banghead: :banghead: :banghead:
So I will either have to:
1) Take at least one of the off and reposition it.
2) Take both engines off and reposition both of them.
3) Leve it as it is as unless you look fairly closeley you do not notice the difference.
Personaly I am favouring option 3 as it is the least work and it also meens I have a good reason to build a second one...... Maybe Japaneese ?
If you do decide to build a second, have a word with either myself or Martin.  Looks like an ideal resin conversion and as yet no one has done a Meteor F2.
Quote from: Gondor on March 23, 2011, 05:58:21 AM
Seems the sensible approach to me mate
Quote from: NARSES2 on March 23, 2011, 08:18:31 AM
Personal I am favouring option 3 as it is the least work and it also means I have a good reason to build a second one...... Maybe Japanese ?
Building a second Meteor F2 or making it Japanese?
or Both?
Build the second as a master...
Quote from: The Wooksta! on March 23, 2011, 02:38:50 PM
Lee I could probably build an engine by itself as a master as both port and starboard engines were the same. Yourself or martin could PM to discuss details about this.
Managed to get some work done during the week. At home today as the plumber had to get in to fix a leak so I should manage to get some more work done.
Engines almost finished which will leave simply the fuselage, upper wing surfaces and then the undercarriage and painting and only 3 weeks untill my self imposed deadline ends !!!
Quote from: Gondor on March 23, 2011, 11:20:12 AM
or Both?
Sorry Alistair I wasn't clear. Finish this one and then build a second for whatever scheme you want to put it in ? Give it a hook and navalise it ?
Quote from: NARSES2 on March 24, 2011, 03:29:42 AM
or Both?
That's OK NARSES2, think I will just stick to building a Japanese one later and a darn sight more accurately as far as putting the engines onto the wing goes.
