avatar_TallEng
Arado Ar. E 555
Started by TallEng, March 10, 2010, 05:16:25 AM
TallEng
I know I shouldn't, I've got enough projects, ideas etc going on, but in the end I couldn't resist!
So I am going to try and do;
Revells Arado Ar. E 555 as an Anti shipping variant (after all if it had the range for New York I am sure it could manage to patrol the bay of Biscuits and the Mid Atlantic gap!)
I thought a couple of Fritz X glide bombs would be nice
but they are to big to fit in the bomb bay!! so...
Modified U/C bay ( In my opinion the doors are way too BIG to hang in the wind if you build it as Revell intend)
And then I thought, if you gone to all that bother to fly out into the middle of the Atlantic, found your convoy; you'd be pretty disappointed
if you only had two bombs and one of them missed or went U/S.
So I've added a couple of (modded) Flak 88's with 200 rounds per gun (storage in the bomb bay) and automatic loading (pneumatic with bleed air from the engines)
and a mix of H.E. and Armour piercing shells :thumbsup: that ought to make mincemeat of any unfortunate freighter you got in your (radar ranging, Gyroscopically stabilised) sights :wacko:
Slerski
Very nice idea, these Flak 88 may generate a large drag  ;D but you want to attack ships so  :thumbsup:
« Le MAGIC, c'est fantastique !! » [Sgt Vincent D., FAF armourer]
« Un Pétaf qui s'ennuie est un Pétaf dangereux... »
Great progress already!!  :o
frank2056
Your build looks great! The E.555 is one of my favorite models; it goes together like a dream. I did something similar with mine (minus the big 88):
Allan
Impressive model and good whifhistory.
Allan
Are you going to do a "wave mirror" pattern on this?
TallEng
I am going to try and replicate a wave like camouflage, but not "mirror wave" unless my idea doesn't work/look right :blink:
TallEng
Over due update!
Got distracted by a weeks holiday and a Lightning, and then suffered a couple of near disasters with the Arado!!
I used the sort of glue that melts plastic to fix the weights inside the wing to prevent tail sitting :banghead:
Which resulted in some unnecessary filling, to the underside of the wings.
I also tried to modify the Engines so that the outer pair each side don't sit so close to the upper wing surface,
that also went a bit wrong (removed to much and the wrong angle :banghead:)
Anyway I think I can recover the engines, so I think a couple of progress pictures are in order.
The 88's fairings have been on a drastic weight reduction and improved aerodynamics course!!
I've also added a gun ranging radar pod
Still to do... I think I need to add an Ammunition feed for each gun and a shell ejector shute
and think up a suitable camouflage scheme, oh and finish it in about 10days!! :blink:
I am excited to see more, keep at it and pray for an extension  :thumbsup:
beowulf
very sexy!  :wub:
liking the look of that...coming together very nicely
allergic to aircraft in grey!
