Author Topic: Avro "Alternate Andover" (Modified to Version 1.01!)  (Read 4241 times)
Offline Gondor
  • What-IF SIG
Re: Avro "Alternate Andover" (Modified to Version 1.01!)
« Reply #15 on: December 02, 2010, 01:56:25 pm »
This idea could require radical surgery to the airframe but...........
You could use some plastic sheet off cuts from your local double glazing manufacturer.
step 1) cut a long length of the clear plastic sheet deeper then required for the hight of the windows and longer than you require for the total length of the windows.
step 2) cut a matching slot in the side of your airframe.
step 3) add edging strips on the inside top and bottom of the airframe to support the clear plastic.
step 4) add the clear plastic PSR to shape.
step 5) PSR some more.
step 6) there is no step six!
step 7) polish the now beautify shaped clear plastic untill is it both nice and smooth and also very clear and shiny.
step 8) apply where necessary masks for where your windows are to be.
step 9) paint your fuselage the colours of your choice.
step 10) remove your masks after you have finished painting to reveal a wonderfully glazed fuselage.
simpelz
Offline Pablo1965
« Reply #16 on: December 02, 2010, 03:59:01 pm »
Hard and difficult work.  :thumbsup: :cheers: :bow:
Offline TallEng
  • Often found barking up the wrong tree
« Reply #17 on: December 03, 2010, 07:15:25 am »
sounds like a cunning plan.....
if I can find some suitable clear plastic I might give it a go! :o
Offline Gondor
  • What-IF SIG
« Reply #18 on: December 03, 2010, 01:09:11 pm »
It's what I intend to do for my early Nimrod R1 to get the windows in the right place.
Offline Gondor
  • What-IF SIG
« Reply #19 on: December 05, 2010, 06:57:36 am »
CD cases would work if the curve you are trying to cover is not to large. Also I was not seriously meaning that you insert one piece of clear plastic for all the windows in one go, you could do them individually or in small numbers depending on the spacing between the windows you decide upon.
Offline Pablo1965
« Reply #20 on: December 05, 2010, 01:19:30 pm »
It goes very well  :thumbsup: :cheers: :bow:
Offline TallEng
« Reply #21 on: December 06, 2010, 02:01:58 am »
CD Case's! Now why didn't I think of that :banghead:
I've got loads of those; 'cos I knew they'd come in 'useful' one day :thumbsup:
I still like the idea of sticking in one long strip.... not so much PSR involved methinks.
I suppose I could also try 'heat forming' the case around something the sameish diameter as the fuselage,
to cut down on the sanding/polishing required?
We'll have to see..... :blink:
Offline Andrew Gorman
  • Kitbasher
    • http://
« Reply #22 on: December 06, 2010, 10:13:55 pm »
Elmers white glue will stretch out pretty far, especially if you are using an old bottle!  A dab of clear enamel after it has dried will fill the meniscus and make it look even glassier,  Best of all, if it doesn't work, wipe it off and try again.
