avatar_Daryl J.
Swept wings
Started by Daryl J., October 13, 2009, 10:26:35 PM
Daryl J.
McDonnell Banshee with swept wings might look good, eh?  Especially in its long fuselage guise.
Am thinking of putting a swept tailplane on my Academy B-50 and reducing the number of powerplants to two fictitious turboprops.
Daryl J.
elmayerle
Quote from: Daryl J. on October 13, 2009, 10:26:35 PM
Daryl J.
Take a look at Tommy Thompson's book on US Naval Air Superiority, the swept-wing Banshee, a F2H-4 cross with the XF-88, was definitely considered.
--Jane Wagner and Lily Tomlin
Daryl J.
So, in other words, taking two Testors 1/48 Banshees and a Lindberg XF-88 and bashing them together would still qualify as a whif, but only as a near-reality whif eh?   Cool!
:cheers:,
Daryl J.
Something I did a while back:
elmayerle
Quote from: apophenia on October 17, 2009, 06:43:35 PM
A bit of heresy inspired by the Bell L-39  :wacko:
The basic concept looks good, but I think you'll need to adjust the main landing gear a bit to get something that works with the leading edge devices and if you move the main gear aft, you may need to extend the fuselage to get the pilot's line of sight reasonable when taxing before takeoff.  The L-39 had the benefit of converting a tricycle-gear aircraft.  Now, if you were to accept the main gear location of a F-86 wing and the nose gear from a T-28, you'd have a rather different proposition.
SSgt Baloo
Not older than dirt but remembers when it was still under warranty.
Anyone else think we could add this to the GB's list?? I think it could work pretty well.
As much as I think this looks really cool, I think it would have a serious problem actually flying.  The L-39, which was really a P-63, was found to be way out of wack with the center of lift in the wings much too far behind the cg point.  To remedy that Bell first replaced the P-63 four blade prop with a three blade P-39 prop to try and save some weight up front, when that didn't really help they added a four foot rear fuselage plug just behind the engine.  But this is with a center mounted engine not with the engine way out front like your Mustang does.  Incidently, there was a Reno racer Mustang that had Learjet swept wings fitted, I've got a model of it somewhere in the stash which is produced by High Planes.  The real thing crashed by the way ---- .
Mind you, if you did that with say a P-82 fuselage, and have the root leading edge as far forward as possible, it could work I think.  But Evan could probably tell you more about that.
This is a top view of the Learstang called Vendetta, as you can see this didn't have a very swept wing
Stargazer
Quote from: kitnut617 on October 21, 2009, 03:11:27 PM
I had the exact same feeling looking at the picture... Too much weight to the front.
elmayerle
Inerestingly enough, one thing the Mustang and Learjet have in common is single-piece wings that are joined to the fuselage by a few large bolts.  I rather suspect that any Learstang effort is going to have difficulties in redesigning the Learjet wing for a taildragger main landing gear and then in making certain that the aerodynamics for stability and control are adequate for what you're tyring to do.  To keep it simple, the quarter-chord line of the new wing needs to pass through the same fuselage station, on the centerline and you still may need to do some juggling to get the cg in the proper location.  I suspect it's doable but with considerable care and calculation.
Daryl J.
How about mildly swept wings on a slightly lengthened Albatros D.V?
What if the Tu-95 had evolved from the Lancaster rather than the B-29?
Love this idea
batmancustoms
John 'Panzer' Hinton
http://www.batmancustoms.com/
What about a DH Vampire or Venom with swept wings? That would look good.
Joncarrfarrelly posted a Venom with DH.108 wings in the Venom/Vampire/Swallow thread:
http://www.whatifmodelers.com/index.php/topic,22690.0/highlight,vampire+venom.html
