Vulcan trainer, the Jet Provost T6
Started by PR19_Kit, April 10, 2009, 03:07:09 PM
While we were at Cosford at the weekend we shared Hangar 2 with some excellent experimental aircraft, one of which was the Avro 707C WZ744, the prototype of the proposed 2-seat trainer for the Vulcan programme. In the end the MoD cancelled the production order for the rest of the 707Cs leaving '744 as a singleton. The a/c was later moved to A&AEE Boscombe Down for many years (no, she never was painted in Raspberry Ripple............) and later at Farnborough until being taken on charge as a museum exhibit in 1967.
This meant the RAF never did have a pure delta trainer, apart from the Javelin T3, so prospective Vulcan pilots had to learn their trade on non-delta aircraft before converting to 'the real thing' at RAF Waddington when posted to 230 OCU.
So suppose in the mid-60s Bomber Command found it started having problems with pilots getting used to the high angle of attack approaches needed for landing a Vulcan and required a new delta trainer...........?
Watch this space........... ;)
Reminds me of the Skyray that the USN Test Pilots School used in the 60s - "So pilots would have experience of flying a plane with poor handling qualities" :o
Howard of Effingham
here's hoping this won't upset anybody!  ;D
Keeper of George the Cat.
Quote from: Howard of Effingham on April 11, 2009, 02:04:26 AM
Howard,
As if.............  :lol:
And Overkiller's on the right tack, but wrong airframe to start with.
Martin H
Delta winged Lightning by any chance?
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Runway ? ...
#5
A glass nosed Vulcan for the training pilot or an extra cockpit grafted on where the backseaters should live or a twin Vulcan with two complete crews in the different noses or.. or ...     ;)
Javelin seems a natural, they were being reitred in droves in the sixties.  But a JP with delta might work for something a bit lighter & less expensive (& look roughly on the lines of the 707), or maybe even a Gnat!
Quote from: Mossie on April 11, 2009, 05:54:39 AM
Got it Mossie.  ;D  :thumbsup:
It's an Airfix Strikemaster/JP5 with the wings from an ancient, part built, FD2 that I found in The Loft. They fit amazingly well, even the bulge round the intakes fits! I'm trying to figure out what to use as a fin as the JP one looks silly with those wings. Perhaps carve the FD2 fin to a pseudo-Vulcan shape?
And what colour scheme? Silver with yellow bands would look great, but the RAF had switched to red/white by then. I toyed with painting it in low level camo, but it would look just like a toy Vulcan......
It's just a detail, but the blue Cranwell band might add a little to the red/white scheme.  A display team might just fit in if it was before 1965 or possibly even the Red Arrows?  A pre Raspberry Ripple ETPS bird might have worn pretty much anything in the late sixties, your 'Testing Colours' book might yield some inspiration???
Quote from: Overkiller on April 11, 2009, 09:48:08 AM
Only £18.50 for a resin T.7 conversion, now to figure out what to use for the wings.....
Duncan,
Ouch, that's heavy money! How about a Matchbox T7 off eBay, assuming you can find one, and stick that onto the Revell F6? Who does that resin conversion anyway?
Quote from: Mossie on April 11, 2009, 09:51:37 AM
Mossie,
So many schemes, so little time.  ;D (and so few FD2s to make them as well!)
I like the idea of the Cranwell band, and the early ripple scheme too, but it's meant to be with 230 OCU at Waddington.
Maybe a pseudo-mini-Vulcan display team? The Red Wedges perhaps?
Quote from: PR19_Kit on April 11, 2009, 08:32:18 AM
Airfix Gnat? Cheap as chips and you can chop as many of those damn things up as you like with my blessing....
It does look right with a delta too - exhibit a:
Duncan,
Gotcha, I should have guessed!
Those guys make good stuff but they seem to be trying to fix a Belgian-UK balance of payments problem all on their own. Don't Aeroclub still do their vacform T7 conversion? I found one in my Loft only tonight, looks quite nice too.
Quote from: Weaver on April 11, 2009, 01:53:40 PM
Weaver,
That does look the business indeed! And I like the little radar nose too.
I wanted a side by side config. though, to go with the Vulcan setup, and I've already started cutting plastic, pics tomorrow with luck. Darned if I know what to do about the landing gear, the JP5 wheels are wider than the FD2 wings at that fore and aft position. I may have to go with shortened FD2 lever action legs.
And quite what I'll do with all the bits left over I have no idea!
I played around with a JP5 drawing I found on the net, added a Vulcan shaped fin and roughed in the delta wing shape.
Any thoughts about this?
It may do, but it'd be difficult to modify the kit to do it. I was thinking of raising the leading edge further up the intakes instead. I'll be trying exactly that later today, fingers crossed...........
Right, it's all happening now........  :lol:
First shots of the modded FD2 wing attached to the JP5 fuse with the mini-Vulcan fin core taped in position. The wing has the Phase 2 leading edge added from a strip of styrene and there's some packing glued between the root and fuse, but not much. There's a socking great hole underneath of course, where the JP5's wing carry-through structure went, and I'll fill that with part of the old wing, but I forsee hours of PSR work.  :angry:
Won't be much progress next week or the one after as I'm having to do some work for the 'old firm', but at least I'll get paid for it!  ;D :lol:
