NAA SST
Started by Orne M, March 15, 2009, 01:14:35 AM
Orne M
Pulled this one out of storage to work on it.  This is a 1/72 variation on the AMT B-70, the NAA SST from the early Sixties (all the construction was done up to this point before I found some NAA artwork on the net).  The fuselage uses the entire AMT B-70 upper fuselage, but have scratchbuilt over this the mid-cabin area and aft fuse-cap from sheet styrene and large applications of bondo.  The wing is the B-70 center-section (light grey), kitbashed with Testors SR-75 lower wing/engines (darker grey) - a good feature was the humped lower belly similar to the L-2000 SST, where luggage/cargo was stowed - and the rest (white areas) were scratchbuilt from styrene sheet.  Haven't decided on single tailfin or twin-fins.
Orne M
A few more shots of the lower wing and engine nacelles.
Martin H
You dont do things by half do you?   that monster should look great when done
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
sideshowbob9
Wow! Looks great! Can't wait to see the finished article  :thumbsup:.
lenny100
That's going to be one large table filler but it will look spectacular
Great!  Is this a real project?  I've seen some designs for SST's based on the B-70, but they simply had cabins in the exisitng fuselage with little changes otherwise.  I like yours much more wether real or not, much more considered.
Dang that is very cool :mellow: Excellent scratchin :wub: :thumbsup:
MartG
Murphy's 1st Law - An object at rest will be in the wrong place
Murphy's 2nd Law - An object in motion will be going in the wrong direction
Murphy's 3rd Law - For every action, there is an equal and opposite malfunction
Now that's a sexy design! :wub:
Daryl J.
Orne M
Mossie, it's a real project.  Have another AMT B-70 i'm building as the AV-2 with the kinked wings, otherwise stock, should have taken a few shots with the two together.
Cobra
Super Cool :mellow: Looks like Something out of an Episode of 'Thunderbirds' or 'Captain Scarlet'!!!!!! Hope to see More!!!!!!!! :thumbsup: :thumbsup: :cheers:
MarkH262
Looks like a predecessor to the blended wing body concept. Cool design there!  :thumbsup:
Mark
Quote from: Orne M on March 15, 2009, 08:08:27 PM
Excellent, look forward to seeing the finished result!
What time is the crane operator due back to put it back in the shed ?
That's going to be one big, beautiful bird when it's done ! Love the look of it from the underside....very powerful !
