R
Alvis Salamander, Stalwart, Saracen, and Saladin series of 6X6 wheeled vehicles
Started by RotorheadTX, June 18, 2006, 08:11:05 AM
Like the tale of the Grand Slam that modern day 617 Sdqn managed to 'discover' in a bomb dump 'somewhere in England'.
Having had it hauled by truck all the way to Lossiemouth to display alongside their Tallboy and Upkeep bombs, their Armament Officer inspected it, only to find it was not only still full of Torpex, but it still had its fuses in place!!!  :o
That closed the station down for an entire day!
There was a case a few years back where a neighbour of a tinkerer and hoarder inherited his collection, and then had to call the USAF in a hurry because there was an AIR-2A Genie nuclear air-to-air rocket in there! Turned out it was just an empty motor section from a drill round and perfectly safe, but I bet that got his heart pumping for a bit.
When I worked at Woodford, we got a Stingray torpedo delivered for fit checks with the Nimrod. The day they opened the case it gathered a crowd and provoked the customary oohs and aahs. A couple of days later, it disappeared again: turned out they accidentally sent us a live one instead of a drill round! Some time later, another, much bigger, case arrived, labelled "HARPOON MISSILE TEST FIT ITEM" or something like that. Again, the crowd gathered for it's opening, but were disappointed when it turned out to be a length of yellow plastic pipe with lead weights inside it and a NATO shackle on top... ;D
frank2056
Quote from: PR19_Kit on May 25, 2025, 03:36:23 AMLike the tale of the Grand Slam that modern day 617 Sdqn managed to 'discover' in a bomb dump 'somewhere in England'.
Reminds me of "Quatermass and the Pit" (one of my favorite SF movies).
IIRC, didn't Coventry Air Museum get their Hind D delivered with a full magazine of cannon ammo and had to get the RAF to send an armourer round to unload it?
I think you're right H, I've heard that more than once. The crew just handed over the keys and got a cab to the airport terminal.  ;D
The outboard windscreen panels of the Salamander need to be bulged like the cockpit side windows of the S-61L/N
logging machines to look like its namesake.
;D
BTW this is one of the S-61N Shortsky conversions I worked on at Heli-Pro in Bellingham, WA in 1995-1996. I was
in the Electrical/Avionics department, we did a complete rewire from a stripped airframe after it was shortened.
The S-61L and S-61N airframes were shortened by a little over 40". This was accomplished by removing the entire
nose back to cockpit bulkhead, removing the plug that had been added by Sikorsky to create the longer fuselage
L/N airliners, and then reattaching the nose. Removing the plug increased the load by over 1,000lbs simply by
reducing the fuselage area beneath the rotor disc. The helicopter was originally delivered to Hayes Forest Services
as C-FHHD, it was later acquired by Carson Helicopter as shown in the photo.
The forward fuselage of the L/N is the same length ahead of the engine intakes as the S-61R/HH-3E Jolly Green Giant.
If someone wanted to convert a regular S-61/SH-3/Sea King into the longer fuselage airliners, attaching the fwd.
fuselage of an S-61R kit to the centre/aft fuselage of an S-61 kit would get you most of the way.
To drag this thread from the clutches of Thread Drift Virus, has anyone considered modelling any of the following:-
Stentor             Saladin  body with HUMUNGOUS GREAT  speakers for public address /  crowd control /festival use
Psychotropic   Salamander with festival foam or "pharmaceutical"  spray  for raves
Sentry               As above with water cannon/ irritant  or coloured dye spray for quelling the mutinous peasantry
Samovar         Saracen body with armoured tea urns for  front line NAAFI use
Any other suggestions welcome!
Quote from: Rheged on May 27, 2025, 09:25:48 AMTo drag this thread from the clutches of Thread Drift Virus, has anyone considered modelling any of the following:-
Alvis Saturn: a Stalwart fitted with a system for quickly dispensing anti-personnel mines. (Saturn was the Roman god of sowing).
Alvis Scylla: A Stalwart fitted with a mine flail at the front so that it can come ashore clearing a beach as it goes. (Scylla was a Greek sea monster).
Alvis Selene: A Saracen fitted with a huge, early image intensifier on an extending mast in place of the turret for night-time battlefield surveillance.
(Selene was the Greek goddess of the moon).
Alvis Sibyl: A Saracen fitted with ELINT/SIGINT gear for gathering intelligence by eavesdropping. (Sibyl was a priestess of Apollo who issued prophesies about things to come).
Here's another couple of Sci Fi style Stalwarts used in TV and films.
From the 1996 movie Space Marines:
https://www.imcdb.org/vehicle_1050431-Alvis-FV-622-Stalwart-1966.html
From The Grand Tour:
https://www.imcdb.org/v995766.html
Martin H
Quote from: Weaver on May 25, 2025, 11:33:07 AMIIRC, didn't Coventry Air Museum get their Hind D delivered with a full magazine of cannon ammo and had to get the RAF to send an armourer round to unload it?
Not quite the case.i was there when the hind arrived at MAM. The gun was found to be live. But unloaded as it had been used as the prototype for a BAe update project for the Hind D. Hence its paint job. Which the museum is not permited to change due to terms in the hand over paperwork.
The museum had to have the barrels replaced with soild replicas and have the real ones scrapped to keep the local police happy.
 Its rumored that the Hind at weston supermare was the one that was delivered fully tooled up. However the czech airforce is usualy mentioned as the guilty culprits. Yet the weston Hind is an ex east german example.......
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Quote from: Martin H on May 27, 2025, 01:34:46 PM
Ah, right - thanks for clearing that up.
I give you the Arcadia Bug, a mobile amphibious dance stage! Ticked off the list as real world.
https://www.arcadiaspectacular.com/installations
https://youtu.be/h2uQTnimeBc?si=a1545ancEUCJfx1hhttps://youtu.be/h2uQTnimeBc?si=a1545ancEUCJfx1h
I was tipped off by a Jadlam models email,  they're based in Glastonbury and some of their staff spotted it at the festival. The wing cases are submarine moulds and the platform is extended to take them.
http://www.sixmania.fr/en/the-bug-arcadia-2007/
Quote from: PR19_Kit on July 02, 2025, 09:55:59 AMStrewth, who'd have thought it? :o
Wonder how many pints (other substances are alledgedly available) it took to come up with the idea  :drink:
Nice to see it being used though  :thumbsup:
Quote from: NARSES2 on July 03, 2025, 12:42:25 AM
Enterprising!  A 12 inch to the foot scale whiff.
