avatar_GTX
Messerschmitt Bf109 Ideas
Started by GTX, September 06, 2008, 02:41:02 PM
elmayerle
Quote from: GTX on October 17, 2008, 12:58:47 PM
An interesting find - Me-109 V31 with belly radiator and wide undercarriage:
If memory serves me correctly, the main gear is fixed down.  This aircraft was a testbed for the gear and cooling system proposed for the Me-309.  Putting a wide-stance main gear on the Bf-109 would require considerable redesigning and restressing of the wing.  I won't say it couldn't be done, just that it'd be a decided effort to do so.
--Jane Wagner and Lily Tomlin
>Putting a wide-stance main gear on the Bf-109 would require considerable redesigning and restressing of the wing.  I won't say it couldn't be done, just that it'd be a decided effort to do so.<
That's what they did with the Bf-109H (high-altitude version)--added a constant-chord wing section extending from the fuselage. It was as if the wing and landing gear of the normal Bf-109 were moved outward by about four feet. The attachment points for the landing gear on the "real" Bf-109 were on the fuselage, so I don't know quite how they worked it into the wing extension.
sagallacci
Also, the Me209V5 and beyond also had inward retracting main gear to go with the all new wing.
Americanised Bf-109 (or maybe that should be a Curtis product...):
and of course, one couldn't ignore the larger brother:
Quote from: apophenia on April 12, 2009, 03:26:13 PM
On the rivet-counting dweeb side, you don't need the P-40-style nose radiator. Attached is an XP-40 style cowling with just the oil cooler.
Yes, I know - but it looks better this way!
Cybermax
#50
Just a Bf109K-4 with wide undercarriage.  I modified a drawing from wiki and only the front view to demonstrate it.
A future build for me is YET ANOTHER 1/72-scale Bf-109T carrier fighter (I have made several of the "standard" ones), but this time I'll whif it a bit more. 1/65 Snap-Tite Bf-109 for slightly added bulk, Me-209 rear fuselage (will be a few feet longer when added onto the larger Bf-109 Snap-tite) and tall tail, Bf-109 H extended wings with wide-track undercarriage, and....Ki-100-type radial engine and nose (I've measured it--a perfect fit). I think I will keep the Bf-109 canopy/turtledeck for the Bf-109 *LOOK*, but am considering the BV-155 canopy.
Sorry, don't look for it anytime soon---other projects are in the near end of the pipeline. It's a DEFINITE MUST, as it will include the nose from an unused "master" for a Ki-100 limited-run resin kit I made for Model-Aire International back in the 80's. Turns out some parts of my master would have been too hard to mold, and Tom Young and I shelved the project anyway, since FineMolds had just come out with their injected version.
famvburg
       Like the Bf-109X?
Quote from: sequoiaranger on September 15, 2008, 06:15:15 AM
On another thread (German forces in the Pacific), "Glenn" posted this pic of a German Ki-100 (hope it's OK to post, Glenn). That got me thinking about the "radial-engined Bf-109" also in another thread here and....since the Ki-61 Tony in-line-engined fighter is the basis for the Ki-100, why not put such a radial conversion on a Bf-109 (presuming some dire restriction on the output of DB-605's forcing Messerschmitt to look elsewhere for powerplants)??
famvburg
   A little Post WWII, & maybe even a tad OT since it's regarding the Hispano Ha 1112 Spanish 109, I've wondered about a Reno racer based on the Ha 1112, using a Griffon with c/r props from a Shack, since the 1112 was already fitted with a Merlin, swapping to a Griffon would be easier. The c/r props would ease narrow gear issues It would be fitted with a larger tail in both horizontal & vertical area & of course a sleeker canopy & clipped wingtips.
elmayerle
How about just going with a more streamlined canopy rather than cutting down the rear fuselage for a smaller one?  *smile* Along those same lines, I've got the bits and pieces back home to take the contra-prop version of the Spitfire Mk.21 and add on the streamlined canopy from the "Speed Spitfire" to make a racer.
Daryl J.
Graft in a Ki-61 wing?   Or Mc-202 for that matter.
Sauragnmon
The Ki-61 wing wouldn't be too bad, if you used the 61-1 wing, and made sure it had the fittings for the 20mm guns - otherwise you're looking at one poorly armed machine even for a G-6/K-4 upgrade - four rifle caliber MGs, and a Motorcannon if you're lucky.  Two heavy MGs if you're looking at G-6/K-4 unless you add cannon fittings under the wings or other additional weapons.
Still plan on doing one though... and a Ki-61-III.
Daryl J.
Would the aircraft then be called 'Heinrich'??    :wacko: :wacko:
Daryl J.
I posted this in other thread:
Hi Gang,
What do you think about a Bf-109E (I like squared wings) with a nose of Buchón type, bouble top and squared tail fin/rudder?
apophenia suggested this:
Instead of lowering the '109 rear fuselage, what about raising the upper cowling Spiteful-style. That way, the canopy is raised and the pilot could sit above a larger fuel tank.
Well the point is ...: I have begun this project! :cheers:
Quote from: ysi_maniac on November 25, 2009, 07:19:51 AM
Hi Gang,
I guess it would have the appearance like a Me.262 Carlos
