avatar_John Howling Mouse
A380 Cockipt Panorama
Started by John Howling Mouse, April 27, 2008, 10:45:55 AM
Probably the best 3D panorama view I've ever seen: when you zoom in, you can read every instrument and placard.  Love the camera view looking over the fuselage.  What are the two domes aside the central throttle quadrant?
http://www.gillesvidal.com/blogpano/cockpit1.htm
The two domes besides the throttle quadrant are a kind of mouse cursors, instead of having a mouse (like on your PC), flying around the cockpit in turbulence... :lol:
Wheres the brakes? :unsure:
AeroplaneDriver
Quote from: B777LR on April 27, 2008, 01:14:44 PM
It's a trackball controller for the Primary Flight Displays and Multifunction Displays.  To make them easy to use in a dark flight deck and in turbulence the dome is where the pilot's hand rests, with his or her fingertips resting on the ball.  I've never flown anything with this system, but I've played with it in the cockpit of a Falcon EASy.  It's pretty neat, and feels very natural to use.
Quote from: AeroplaneDriver on April 29, 2008, 05:49:40 PM
Ah, ok then, was slightly wrong...
But i assume you would know where the brakes are located? Stopping any aircraft without wheelbrakes must be difficult?
Archibald
Even more if you consider an A380. Really need STRONG brakes to stop such mass...
"An apple a day, keeps the doctor away" (proverb) "If you aim well !"  (Winston Churchill).
AeroplaneDriver
#5
Quote from: B777LR on April 30, 2008, 04:22:20 AM
I wouldnt say you were wrong at all, I was just addiing some more detail.  Teh wheelbrakes are on the rudder pedals.  If you push the entire pedal you actuate the rudder and nosewheel (though main nosewheel steering is through the little steering wheel on outboard of the sidesticks), but pushin in on just the upper part of the pedal actuates the wheelbrakes for the respective side.  Normally stopping the aircraft during landing or rejected takeoff is done with autubrakes, which can be selected at different levels depending on runway length.  Between the autobrakes and antiskid the wear and tear on the brakes and tires is generally a lot less with autobraking that manual, though maual is always available if needed and is always used to stop while taxiing.
(All this brake mumbo-jumbo applies to just abaout all transport category aircraft, not just the 380)
Looking at this panorama thing again I'm a bit surprised at the jumpseats.  The 777 has a nice comfly, full sized non folding jumpseat, plus a folding one, but it looks like the like the 380 just has the god-awful uncomfortable folding ones.  I once jumpseated to Heathrow on United and went on a 777 that was reallllly comfy, then had to come home on a 767 that was 7.5 hours of hell.
