M
'braille Scale'?
Started by MerlinJones, May 27, 2007, 08:20:19 AM
MerlinJones
I'm currently working on a Modelling Glossary. When it came to Braille Scale, I've had diferent definitions. Some suggest it's larger scales, others that it's smaller scales.
Any thoughts?
Bruce
RotorheadTX
To my understanding, it's 1/144th or 1/200th for aircraft, or 1/72 or 1/76th for armor. That based on the conventional wisdom that 1/48th and 1/72 are the standard scales for non-airliner aircraft models, and 1/35th is de rigeur for armor.
Scooterman
And as my good friend Ken says 1/32 aircraft is MANLY SCALE!
1/600, 1/700, 1/400, 1/1200 = ships
AIU, 'braille scale' refers to the really large scales (e.g. 1:32 and 1:24 for aircraft, 1:12 for cars). The thought being that even small details are large enough that they're suitable for people with bad eyesight.
Archibald
Quotethe conventional wisdom that 1/48th and 1/72 are the standard scales for non-airliner aircraft models
Alas!!   :(
McGreig
QuoteAIU, 'braille scale' refers to the really large scales (e.g. 1:32 and 1:24 for aircraft, 1:12 for cars). The thought being that even small details are large enough that they're suitable for people with bad eyesight.
I agree. That's always been my understanding of "braille scale" .
MerlinJones
Thanks for the input guys...
Although there are one or two who believe that Braille scale is for the larger scales, (kits you can build with your eyes shut and by touch alone), the majority seem to share the consensus that Braille scale is the smaller scale. For AFV's, this tends to be anything smaller than 1/35 and for aircraft, anything smaller than 1/48.
One theory has it that it came about as a counter to those who built aircraft kits and repeatedly proclaimed 1/72 to be The One True Scale. "You must be blind", went the response...etc..
Smaller scales it is, then.
(Of course, this might change!)
Bruce
Alas!!   :(
Why? With the majority of airlines today painting their aircraft "eurowhite", it would be a bitch to paint them ;)  (and we all know how much you hate painting white ;) :P  )
Nigel Bunker
#9
i have checked some early issues of SAM, particularly the Mike McEvoy column Tailpiece, where braille scale is the term given to 1/48 kits by 1/72 modellers, the idea being that they model in larger scales because of failing eyesight.
1/72 was referred to as the Gentleman's Scale.
Spellbinder99
Exactly Nigel. 1/48th is referred to as Braille Scale as when you are too blind to see parts in 1/72 you move up to Braille Scale.
I definitely don't think the consensus is that it refers to smaller scales like 1/144 or 1/200.
Cheers
Tony
I had always thought it was the smaller scales myself, but the argument for stepping up to 48th from 72nd does make sense.....
Archibald
Alas!!   :(
Bog, I've mastered white paint on the Sonic Cruiser in the end. I think airbrush could help solving this problem.
Well, airliners exist at 1/72 scale, they are just vacuform  ;)  models.
