A Bit Of Help Needed
Started by lancer, January 06, 2007, 02:57:37 PM
Ok, I've got this built and to the painting stage. All mods done and PSR cycle completed. Mods are 1) Upper turret deleted and faired over 2) glazed nose atached and then 3/4 cut off and the 'short' nose left over from my Meteor added and faired in - lots of PSR there - I do have pic's if any one wants to see, to make a soid nose. 3) 2 cannon ports drilled into the lower part of the nose and 4 hole's drilled for the 4 .50 guns that are going in the nose.
I have also taken the 60lb rockets from my revell Tempest and thee are going to be attached under the wing.
It's going to be a CAS/CoIn machine based in, probably, South America. I need to get the Zotz sheet for it still.
What I need is some accurate ideas for a top cammo scheme. I've done some research on the web, but not really found much. I have had my own idea for a 3 tone scheme of tan, light green, medium green, but I don't know how close to real tis will be. SO, could any one please give me some ideas before I faff th whole thing up.
Thanks
Lance I've a Mystere 4 done in a real Bolivian F86 colours - topsides are 3 reen, green/greys oer grey - looks quite nice.
I can dig out some of the artwork with the transfer sheets for Milton Keynes if you want ?
Um, whats the model Lance?  :unsure:
Hmmm, you could do it Brazilian to fit in with Chris's scenario?
I would suggest Israeli, but I know you wouldn't do that.
RAF'46?  In Germany?  Invasion of Singapore?  NMF with SEAC roundels and blue ID stripes?  :wub:  :wub:  :wub:
Late 40s Luftwaffe, re-formed to combat the Red-Tide?  Sounds ideal for plinking regiments of JS-3's  :tank:
retro_seventies
RAF in suez?
RAAF in suez?
RNZAF in suez?
you my have noticed a "suez" motif there....i think it's because you get to use a desert scheme AND stripes... :wub:  :wub:  :wub:
imagine your marauder dressed like this but in browns intstead of greys...
super yummy!!!  :wub:  :wub:  :wub:
Lance, theres two here from Don Color, one from Venezeula, the other Peru:
Venezeulan F-16
Peruvian Mirage 2000
Both have painting diagrams with FS colors.  There may be more, these are off a 'exotic plane schemes' siter site, the main sites having difficulties.  I'll try & drag some off there for you when it feels like playing.
There's plenty of other diagrams from other parts of the world too, worth a look.  It includes US aggressor schemes, they're usually damn close to the originals they're based on:
http://users.skynet.be/exotic.planes/htm/o...her/schemes.htm
No South American schemes, but IPMS Stockholm has all sorts on their colour charts, all to FS.  Of cousre, they are the be all & end all for accuracy ;) :
http://ipmsstockholm.org/colorcharts/colorcharts.asp
Thanks for all the help fellahs, I can get on and work some good schemes out from this little lot.
