avatar_Chris707
V/STOL Typhoon
Started by Chris707, December 12, 2006, 12:18:47 PM
Chris707
From a 2003 BAe patent - hedge against F-35 cancellation/non-participation I'd wager...
Apparently, the aft portion of the ductwork would be stowable, with the forward area being collapsible...
V/STOL: A History in Patents
http://www.dataviewbooks.com
Wow, that looks impractical to say the least. Wonder how the Typhoon would look with an F-35 style lift fan aft of the cockpit.
AeroplaneDriver
Good grief!  It looks like Wallace & Grommit designed it!   :o
RLBH
It looks very, um, British. Bodgit and Scarper, and so forth. One heck of a maintenance hog, I guess.
Sisko
Is someone taking the piss <_<
Get this Cheese to sick bay!
Looks like they've designed a good way to use the jet exhaust for heating large buildings......
anthonyp
I exist to pi$$ others off!!!
Archibald
Just a silly question : whatif the EJ-200 of a Typhoon were replaced by a pair of Pegasus ? After all, late variants of this one (AV-8B+) deliver 11 tons of thrust even without reheat... that's more than the EJ-200  :wacko:
I suppose that heavy mods would be needed... hot shot engeneer, we need your wise advices!
"An apple a day, keeps the doctor away" (proverb) "If you aim well !"  (Winston Churchill).
GeorgeC
It is not an act of war...
Figure 5 is dangerous, coz engine might inhale its own exhaust... :unsure:  nr 6 also looks bad :unsure:
harrier
In 2003 I went on a V/STOL aircraft design course at Cranfield. I remember the Warton lads drank a lot, but really....! "Pay attention at the back!"
There were various schemes for canard V/STOLs from Warton in the 1980s, and one used a RALS scheme (also known as 'bleed and burn'!) with a duct taking fan air from an aft engine to a ventral fuselage burner aft of the cockpit. It was the P112, picture in BSP Fighters. But hot gas like the picture above? Still, Nick Park is from Preston!
BAe P.1216 Supersonic ASTOVL Aircraft ProjectTech Profile: http://www.harrier.org.uk/P1216.htm
"If there is a more tortuous tale in the history of aerospace than the long pursuit of a runway-free fighter, the author has not heard it." Bill Sweetman
Mechworker
You can't be serious.
Those are the most ridiculous and impractical V/STOL setups I've ever seen!
I don't know what the intricacies fo the design are, but I can tell you that looks bad.
I'm a Ph.D. Electrical Engineer, so while I don't know aircraft design, I do know dodgy engineering when I see it. This looks dodgy.
In addition, that woudl impose so much weight and drag penalty, I would think it would more than negate any STOV/L or V/STOL advantages.
This is some of the most ludicrous stuff I've ever laid eyes upon!
there are some good ideas for supersonic V/STOL in Gunston's 1986 "Future Fighters" book. Perhaps the boys who designed this abortion should look in there...
Chris707
P1127
There was a Flight report on a STOVL Eurofighter design in the early 80s, using vectoring nozzles at the back and Harrier style nozzles forward
It's not an effing  jump jet.
