avatar_jcf
Lockheed Model 24 of 1937
Started by jcf, November 17, 2006, 11:48:32 PM
Powered by closely-cowled 14-cylinder Pratt & Whitney R-1535s.
Span: 54'
Length: 34' 6"
Wing Area: 404 sq.ft
The Navy didn't go for it but were sufficiently interested to order a Model 12-A as the XJO-3 for carrier tests of the tricycle landing gear. The aircraft was flown off the Lexington during August of 1939.
A revised Model 24 was later proposed with non-supercharged Allison V-1710s, during the war Lockheed proposed the Model 822...basically a P-38H with a strengthened airframe, folding wings and arresting gear.
So USMC/USN night-fighter units?
Cheers, Jon
Archibald
Navalised P-38 for the Aeronavale and RN...  :wub:  :wub:
"An apple a day, keeps the doctor away" (proverb) "If you aim well !"  (Winston Churchill).
Nice spats! :wub:
Did I mention that I love spats? :wub:
QuotePowered by closely-cowled 14-cylinder Pratt & Whitney R-1535s.
Jon,
If you hadn't added this statement, I would never have realised that it was powered by radial engines - talk about closely cowled!  I have heard that there was a proposal for a radial engined (Pratt & Whitney R-2800s, I believe) but I think this was later on.
QuoteNice spats! :wub:
Figured you'd like it.
Jon,
There is a "What-If" model floating around the web of a twin-radial Sea Lightning, but the only real-world proposal for the Navy using radials is the one I posted with the R-1535 Twin Wasp Juniors...the rest of the Lockheed proposals all used Allisons.
I have read mention in passing on various boards that Lockheed had studied re-engining with R-2800s...but I have never seen any written references or details, and actually it would make little sense.
Cheers, Jon
Son of Damian
Some thing like this, the Lockheed XFV-1 Trident.
If the USN was more interested in aircraft like the XF5F-1 then I could see the model 24 entering service. Though in limited numbers per carrier and mainly for rapid interception (thanks to the two engines) and a long endurance CAP. Maybe later in the war a two seat nightfighter.
- Franklin D. Roosevelt
QuoteIf the USN was more interested in aircraft like the XF5F-1 then I could see the model 24 entering service. Though in limited numbers per carrier and mainly for rapid interception (thanks to the two engines) and a long endurance CAP. Maybe later in the war a two seat nightfighter.
Dunno about the "rapid interception" as the maximum power developed by the R-1535 was only around 825hp. :cheers:
Hughes H-1 was powered by an earlier version R-1535.
Cheers, Jon
