T
Airfix TSR2
Started by The Wooksta!, February 27, 2006, 04:39:37 PM
TsrJoe
did anyone nab a spare Airfix TSR.2 print when they were avaliable, i missed sending for one when they came out :(
cheers, Joe  :ph34r:
I got some prices from some picture framing outfits and they all were around C$300 to frame the print.  I was also told the print itself is worth about C$200.  This more than anything makes up for the fit problems with the kits.
One thing you should keep in mind is that the prints should be 'stretched' properly before mounting in frames, and definately don't glue the prints to anything.
:cheers: Robert
Archibald
Started my TSR-2 today!!! As I also have a Vulcan waiting its demise, I decided to fit its Blue Steel semi recessed under the belly... of the TSR-2. Have to stretch a bit the bomb bay, but aparently it works. After all, the Mirage IV had no bomb bay and carried its AN-52 nuclear bomb recessed under the belly, so why not the TSR-2? hope I wont have problems with the undercarriage :P
"An apple a day, keeps the doctor away" (proverb) "If you aim well !"  (Winston Churchill).
QuoteStarted my TSR-2 today!!! As I also have a Vulcan waiting its demise, I decided to fit its Blue Steel semi recessed under the belly... of the TSR-2. Have to stretch a bit the bomb bay, but aparently it works. After all, the Mirage IV had no bomb bay and carried its AN-52 nuclear bomb recessed under the belly, so why not the TSR-2? hope I wont have problems with the undercarriage :P
The Mirage bomb is about a third of the size of a Bluesteel though.
:cheers: Robert
I read in one of the MAM articles that Bluesteel was discounted at an early stage for TSR2 as it was just too damn big, the main thing being not enough ground clearance.  SAMI produced some 'Blue Water' stand off nuclear missles for just this reason.
I'm not saying you shouldn't go ahead with the Blue steel though, for one thing the blue water missiles are £10 for a set of 2!
Simon.
Archibald
Hey guys, I know that! But I managed to recess the blue Steel under the plane. Just spent three hours scrapping some plastic parts around the bomb bay :P.
The blue steel just fit between the forward undercarriage and the airbrakes.
Just want to make something original... this is also a kind of bet : I want to success were BAC and the RAF failed 40 years ago :P
But I agree, maybe there 'll be a ground clearance problem   :huh: until i change the undercarriage :)
