avatar_McColm
Shorts Windermere MR.2
Started by McColm, Today at 01:50:01 AM
This started as the 1/72 Revell Blohm & Voss Bv222 v5 but had six engines reduced to four R-4360 radial pistons, the wheels from the Academy KB-29P, radome from a Revell Avro Shackleton AEW2, ECM vertical tail pod is off the Mach2 Breguet Br.1150 Atlantic and the MAD boom from the Airfix BAe Nimrod MR.1. Dipping sonar is from the Airfix Avro Shackleton MR.2 retractable radar.
It was originally intended for the Operation Downfall Group Build but I ran out of paint and decided to make a few modifications which will include the LACI CV-580 Allison 501 turboprop engines which after dry fitting and a bit of fettling do fit. Just need to get another set .
Backstory:
 SJMcColm Engineering Limited brokers an agreement with Blohm & Voss to build the BV 222 Wiking under license for the transatlantic passenger and cargo routes, carrying 90 passengers in comfort (business class). Fitted with six R-3350 radial engines. The alterations are carried out by Short Brothers to produce the amphibious layout. The Mark 1 having permanent fitted wheels, the Mark 2 would get the retractable landing gear and better soundproofing. The first seven Mk 1s were converted into freighters with the remaining nine upgraded to Mk 2 standard.
 During World War II the Shorts Windermeres were painted dull green and only flew at night for the passenger service, the seats could be turned into beds. The Air Ministry carried out a study of using the freighter version as an anti-submarine hunter in a similar manner to the Shorts Sunderland, they were flown by 201 Squadron. After the war SJMcColm Engineering Limited were given the contract to replace the Sunderland and the Avro Lancaster in the maritime surveillance role. Sunderlands reduced to the Search And Rescue duties. Forty Windermere GR.1s would be used by Costal Command, five would be brought up to V.V.I.P. standard all with retractable landing gear and sixty built for commercial customers.
 With the Golden Age of the flying boat beginning to fade SJMc began to replace the radial engines with Allison 501 turboprops which meant that the outer engines were replaced by fuel tanks this prompted the RAF during the 1960s to fit thirty-five with  Rolls-Royce Tynes, new avionics and underwing pylons although the winch system was continued. The guns removed and new technology installed. Export customers were few but the US Coast Guard would place an order for fifty with South Africa ordering nine examples and spare parts for five.
 During the 1970s a replacement was sort, the best MR.2s kept for the TAPESTRY flights and SAR reducing the numbers down to twenty-four, SJMc would buy the surplus rather than the scrapman's cutting equipment.
 All  Mk 3s were rebuilt aircraft using modern materials and technology during the 1990s, the Windermeres received a lifeline by the United Nations in the relief and natural disasters as they could access areas that a helicopter might have problems landing. The Allison 501s upgraded to the T56s.
 With the retirement of the BAe Nimrod from service the Shorts Windermere MR.3P stepped in as a stopgap in the maritime patrol role and SJMc had been working with Norhrop-Grumman using the AN/APS -145 radar these fitted to the upper fuselage to replace the Boeing E-3D Sentry. Twenty of each variant remains in service with the RAF.
