avatar_nönöbär
Perry Rhodan Fleetbuilding Program
Started by nönöbär, June 21, 2026, 02:35:53 AM
Steel Penguin
quite a fleet now, and looking good,  consistent design feel to them all.  :thumbsup:
nönöbär
Printing the Fleet
These days you could almost call it printing the fleet. Since cleaning up resin prints is the least enjoyable part of the process, I usually collect several print jobs and then run a large batch all at once.
That means there are quite a few new spaceships currently in production. Everything shown below has just come off the printer, none of the parts have been cleaned or UV-cured yet.
Three more 100 m cruisers with their landing legs. The legs are extremely delicate, and I only have about a 70% success rate removing the supports without breaking at least one of them.
Two 200 m cruisers with their landing legs. These are much easier to handle because the larger parts are considerably sturdier.
A mixed fleet. The spherical ship is a 200 m Arkon cruiser, while the remaining models are various spacecraft I found on Thingiverse. In my fictional setting they will serve as civilian or alien vessels. There are also a couple of disc-shaped Space-Jets; in "reality" they measure between 30 and 55 metres in diameter.
Speaking of the Space-Jets, they are tiny. Really tiny. The models measure just 10 mm and 13 mm across, which makes the landing legs incredibly fragile.
Wire or brass rod is your Friend there...  :thumbsup:
Andrew Gorman
I've heard an ultrasonic knife is the tool to use to cut 3d printed parts free.  I have never used my cheap one for that but it works better on non- styrene materials. In styrene it is just a less messy hot knife. But mine is an Aliexpress cheapie that doesn't work the way it was advertised.
Quote from: Andrew Gorman on July 12, 2026, 08:02:58 PMBut mine is an Aliexpress cheapie that doesn't work the way it was advertised.
How very uncharacteristic! (He says, having had similar issues...  ;)  )
Reorx
Hi,
i follow your build with great interesst, i´v read the Perry Rhodan weekly till above 2000anything.
May i ask, which vessel will be the largest you´re planning? I´m silently hoping for the Sol ;). Also a Posbi cube ship.
Yours sincerly
Harald
nönöbär
Quote from: Reorx on July 14, 2026, 08:37:23 AMHi,
Yours sincerly
Harald
I have read all3300+ of them. And still reading.
I think I will go for a maximum of 200m ships. One of the Ultrabattleships of the SOL would 65cm. So we have two of them and the middle part, so we would e between 1,5 - 2 meters.
And there is this cosmic entity called WIFE that would not allow this....
Quote from: nönöbär on Today at 04:46:34 AMAnd there is this cosmic entity called WIFE that would not allow this....
Ah, the universal Cosmic Auditor!  :rolleyes:
They can be such uncompromising killjoys, sometimes!  :angel:
