avatar_Geoff
Russian Sabres
Started by Geoff, June 13, 2026, 04:11:32 AM
Geoff
F-86HYou cannot view this attachment.
Charlie_c67
Quote from: Geoff on Today at 05:24:29 AM
Quote from: Charlie_c67 on Today at 04:57:23 AM
Quote from: Geoff on Today at 04:48:24 AM
Quote from: Charlie_c67 on July 02, 2026, 09:06:34 AMI guess with the difference in metallurgical abilities between the two countries, not long if they could make it at all. More likely some sort of Soviet-fied version akin to the VK-1 and Nene.
The VK-1 was too wide so the AM-5 was slated for the clone according to the video
Knew I'd heard of the Russkie alternative, just couldn't think where, probably this video!
Quote from: Geoff on Today at 04:51:55 AMI was also wondering about the armament  and settled on 3x 23mm. Thoughts?
On each side or in total?
In total, I decided the clone was to match the F-86 not a bomber destroyer, so the slow firing 37mm was no good - so 2x 23mm to starboard and 1x 23mm to port. The option would 6x 13.5mm MGs.
I'd have thought a pair of 23mm either side wouldn't be a problem. Might be better for weight distribution as well.
