avatar_frank2056
1/72 Avrocar
Started by frank2056, March 05, 2026, 08:17:39 PM
I had a problem with a resin Enterprise -C once.
I painted the thing and got a topcoat on (spraycan White), then there appeared patches where it looked like something was outgassing (never mind the model was yonks old...); but it all went away soon after, which is good, as it didn't look good against the paintjob...  ;D
frank2056
This model was over 20 years old - so no outgassing. The resin probably wasn't fully cured (or some other resin chemistry issue) - there's no fix for that. Some of the old primer stuck fairly well, but then I could peel sheets of it with no problem. After a wash with denatured alcohol, I sprayed it with Stynylrez primer (which is designed for resin!) and after a day it was gummy and soft, so that was the final straw.
Eventually these really cursed projects just HAVE to be told who's boss, don't they?  ;)
frank2056
I thought about your cursed B-2 when I gave this one the heave-ho!
They both deserve their resting place in Model Hell for sure!   :wacko:
Quote from: frank2056 on March 12, 2026, 09:59:20 PMThis model was over 20 years old - so no outgassing.
The Enterprise was probably about the same vintage - it wasn't a problem when the paint first went on, it only appeared after a while.
Then went away again...  :banghead:
I really need to finish it, but the resin pylons supporting heavy! resin nacelles really should be replaced with a piece of 2mm styrene sheet, bent to shape.
Then a respray...
I've been trying to get the gumption to do that for a couple of decades, now... :banghead:
Quote from: Rick Lowe on March 14, 2026, 07:07:11 PMI've been trying to get the gumption to do that for a couple of decades, now... :banghead:
So, no hurry, then.  :wacko:
Quote from: Old Wombat on March 15, 2026, 02:59:30 AM
Exactly!  :thumbsup:
Quote from: frank2056 on March 12, 2026, 08:26:30 AMThanks, guys. I am working on the BMW beast.
Harold - this came to mind:
Sorry Frank, I only just saw this, or rather I didn't: it's coming up "Image Not Available In Your Region" (because it's imgur).
Quote from: Weaver on March 19, 2026, 04:21:13 AM
[imgur image deleted]http://
This image;
Cheers Womby - yeah, I've seen that one before: you can hear the Colour Police twitching from the next county, can't you... :wacko:  :wacko:  :wacko:
.... and the people who comment that your decal codes aren't 'straight sided enough', or ask why you don't use vector graphics software instead of bitmaps.
Quote from: PR19_Kit on March 19, 2026, 05:26:21 AM.... and the people who comment that your decal codes aren't 'straight sided enough', or ask why you don't use vector graphics software instead of bitmaps.
I've seen one photo where the "Invasion Stripes" were being applied with a broom.  ;D
Mind you those squadrons that wern't required until D+1 tended to have much neater Invasion Stripes. The squadrons used on D-Day it'self of course had, had to have them applied virtually over night.
frank2056
I think the better squadrons got giant decals for their invasion stripes and markings...
Quote from: NARSES2 on March 19, 2026, 06:17:39 AMhad to have them applied virtually over night.
Literally...
I've seen a close-up of a 'Checkertail Clan' P-40 tail and the squares are anything but even, or square...  ;)
With the comment 'Modellers take note and heart!' ;D
