avatar_Dizzyfugu
Done @p.3 +++ 1:72 Rockwell A-8B ‘Destrier’, USMC VMA-311 ‘Tomcats‘, 1981
Started by Dizzyfugu, December 20, 2025, 04:18:02 AM
Thank you. It still looks pretty crude, due to poor Humbrol enamels...  :-\
63cpe
Oeh, this is a very good concept. I like what you're doing. It's great. Go on i like to see this finished..
I like the use of an FJ-4 and an T-2. This gifs very good inspiration for a Vought V433.
Thank you,
David aka 63CPE
Spino
This one's definitely unusual!  Looks good in that camo scheme though, when it's done I suspect the front end of it will be a bit reminiscent of the G.91, but with a prop on the nose!
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
Quote from: Spino on December 25, 2025, 03:20:20 PMThis one's definitely unusual!  Looks good in that camo scheme though, when it's done I suspect the front end of it will be a bit reminiscent of the G.91, but with a prop on the nose!
It has a strong F-84 vibe, esp in frontal view! And with the prop in place it looks like a juvenile Gannet!  ;D
Only little progress after a small setback: the matt acrylic vanish I used turned out to be quite ...glossy. While the finish turned out to be even when dry the shiny look did not look good, so I gave the model another coat of varnish, this time from the rattle can and with a different product. Final assembly next.
