avatar_Spino
Vigilante - The Practical Kind
Started by Spino, July 01, 2025, 06:22:30 AM
Nah, A-5Bs don't really count as 'bombers' even if they are. The REAL ones have narrow backs.  ;D
There have been articles in various places on how to convert the Hasegawa kit into an A version.
Spino
Quote from: PR19_Kit on July 06, 2025, 04:57:47 AMNah, A-5Bs don't really count as 'bombers' even if they are. The REAL ones have narrow backs.  ;D
Well, if I recall correctly, none of them ever actually carried bombs in practice anyway.
I'm conflicted about what time period to set this one in.  Mid '70s would let me mount AIM-9Hs on the LAU-7 rails that I added to the outer wings, but it might be too early for the AGM-123s that I'm planning to mount on it.
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
I built a twin tail vigilante about 15is years ago, using f-18 tail fins. It's a no service during the early 2000's, with low viz markings, and armed with SRAM 's. It was the trumpeter kit. I also put bigger exhaust nozzles on it too.
Here it is. I put a different nose on it too.
Oh yeah Chris, I LIKE that, a LOT!  :thumbsup:  :thumbsup:  :thumbsup:
How did the Trumpeter kit go together?
Spino
Mine is also a Trumpeter kit, it definitely has more detail than the Revell models I'm used to, but the fit and finish wasn't bad.
Regards, Spino
Quote from: PR19_Kit on July 08, 2025, 07:17:11 AMOh yeah Chris, I LIKE that, a LOT!  :thumbsup:  :thumbsup:  :thumbsup:
I read that they are not a good kit to build, but from what I remember, it wasn't that bad.
Scotaidh
It appears to be a cousin of the MiG-25 ...
Spino
Yeah after seeing that A3J mockup with twin tails I can't help but wonder if the Soviets decided to take that basic layout, delete the bomb bay and deepen the fuselage to make space for MUCH bigger engines, and the result was the MiG-25  ;D
Regards, Spino
Spino
Quote from: chrisonord on July 08, 2025, 06:43:44 AMHere it is. I put a different nose on it too.
After seeing that it makes me want to redo mine with a more modern low-viz scheme, but I feel committed now after having put three coats of white on the underside!
Regards, Spino
Spino
The Vigilante has its canopies back on.  The pilot figure is from a Revell F-15C (the kit that I built as an F-15X).  Since I needed a pilot with an HMS for that build, the kit pilot was surplus to requirements but fits perfectly in the Vigilante's front seat.  I painted his helmet red and white, since the Vigilante will have some red in its squadron markings.  I still have some of the original kit decals that I plan to use on it (I used the other squadron option that came with the kit and those degraded rather badly without any clear coat on them).  Not quite sure what I'll do about the roundels yet, maybe subdued grey and white ones to indicate a partial transition to a low-viz paint scheme?
I had a near disaster while trying to drill the hole for the laser turret.  I made the mistake of using a drill-driver with a 5/16" drill bit instead of just using my Dremel with a spiral bit, and the resulting tear-out was rather terrifying.  It snapped the recce canoe fairing almost completely in two and caused a split in the underside of the model.  Thankfully it's nothing a little glue and PSR won't fix, but still a scary experience with a model this expensive!  After fixing it, I came back with the right tools for the job and got the turret installed.  It's from a LANTIRN targeting pod in the Hasegawa Aircraft Weapons D kit.  The hole was a little too big so I had to fill it with putty, once I get that sanded down I'll paint the turret.  Not sure I want it to be white like the rest of the underside, I might make it grey just for some contrast.  Anyway, here it is.  That little turret looks positively tiny on the Vigilante, especially compared to the one on the Pave Tack pod I fitted to my F-107!
Regards, Spino
Yeah, the 'Oops, too far' or 'Shoulda used the Right Tool the First Time' thing has caught most of us now and again...  :banghead:
Good you were able to avert disaster.  :thumbsup:
Spino
Quote from: Rick Lowe on July 31, 2025, 10:06:04 PMYeah, the 'Oops, too far' or 'Shoulda used the Right Tool the First Time' thing has caught most of us now and again...  :banghead:
No kidding!  Grabbing that drill instead of the Dremel could be considered the equivalent of using a sledgehammer to solve a problem that a rubber mallet would have been more than sufficient for!  I'm just glad it didn't do as much damage as it could have.
Regards, Spino
Quote from: Spino on August 01, 2025, 06:21:49 AMI'm just glad it didn't do as much damage as it could have.
Definitely!
