avatar_DogfighterZen
OH-58 Kiowa of the PoAF
Started by DogfighterZen, June 10, 2025, 11:29:44 AM
After several really small decals for the serials... ;D
It's almost there, just have to finish the tail rotor by adding red and white stripes in form of a decal and attach the minigun...
After the final clear coat and nav lights are painted, i'll remove the masks and also do a final detail, which should've been done earlier but i forgot, and that is to paint the top small windows with clear green.
I just hope i won't make a mess at this stage of the build so, if i'm lucky, i may be able to finish it tomorrow after work... that is, if nothing important comes up to ruin my plans... :rolleyes:
A lovely little build Rui mate 👌 👍
I built this kit decades ago and yep ..mine looked like crap 💩 😆
Quote from: Wardukw on June 23, 2025, 01:33:30 AMA lovely little build Rui mate 👌 👍
Thanks, Phill! :thumbsup:
I'm pretty sure you'd make mine look like crap if you built one now. ;D  It's a small but fun kit to build OOB and has lots of room for improvement for those who want more detail. I'd probably buy a couple more of these for a few ideas i'd like to try. :thumbsup:
Well, as always. life got in the way and i still haven't finished this... :banghead:
But there has been some small progress, that being finishing the tail rotor with a red and white stripes decal after paint and glued it in place on the left rear door.
finishing the main rotor by spraying the stripes on the tips.
Also took the opportunity created by the gatling gun's attachment tab being broken off and added the Y -shaped mount with two bits of styrene, painted and attached that to the port rear door.all that's left to do now is to stretch a bit of sprue and cut a thin section to make a thinner antenna for the mast behind the top wire cutter.
After that is done and painted, a gloss coat to seal up the decals and the parts that hadn't been coated yet like the rotors and gun. After that dries, it'll be a final flat coat.
Then there's still the navigation lights and the bit i forgot to do when it should've been done, paint the small top windows with some very thinned clear green but i'll have to be very careful as this could really mess up the build when it's so close to the finish line.
Will be having a few more hours free hours for the next few days because of the heat wave so, i may be able to get it finished this week... :rolleyes:
That's looking bloody sweet bud and you my friend are sadly mistaken  ;D
If you think that I'm capable of building something that small today and making it look good ...that's a big fat nope 😆
If struggle with 48th scale now for a Jetranger in any form now ...just to fiddlely ..35th ? ..yep  :thumbsup:
Like the 1/35 Heller Super Frelon S.A.321 Et Son Helicopter I scored a smeg ago..dude I've wanted one for decades 😀
What I didn't realize is the size of it ..knew it was big but damn!! ...the box alone is 680mm long ..the fuselage is 580mm  :o
Still got one now ..figure out what I'll do with it later 😏  :wacko:
Quote from: Wardukw on June 29, 2025, 10:08:03 PMThat's looking bloody sweet bud and you my friend are sadly mistaken  ;D
 :o I'd need a hangar if i started buying and building everything bigger than 1/48... ;D
But hey, i'm glad that there are kits in several scales to cater for everyone's preferences.  :thumbsup:
Can't say the bigger helos do much for me., though... i'll go as far as the SA 330 Puma in 1/72 and the biggest helo kit i own is probably the Revell 1/32 Jet Ranger.
I'd initially bought that kit for the Blue Thunder action trio build, which includes Colonel Cochrane's MD-500 and one of the LAPD's Jet Rangers that carry shooters to try to force Murphy to land before the pair of F-16s and the 30mm cannon-armed MD-500 gets called in.
The biggest obstacle for that trio to be complete is the fact that the 1/32 kit i own for the MD-500 is actually Hobbycraft's OH-6A Cayuse and the kit is old... I'd thought of scratchbuilding a 5 blade main rotor hub and a 5th blade for it but i'd also have to modify the skids to make the taller ones and the tail would also need work to convert into the MD-500's... and those are just the main changes...
Not that i think i couldn't do it but i'd prefer to have a better kit to save time and work so i've been waiting for someone to make a real 1/32 MD-500 kit or that Revell repop their Magnum P.I. kit.
The Revell Jet Ranger also needs the taller skids but there's a company selling those in 1/32 and they're on my watch list. ;)
Regarding this build, the heat has just gone down enough to allow for some airbrushing so a gloss coat will soon be sprayed to seal everything up and i'll wait an hour. With the temperatures in my studio being over 30ºC at the moment, it should be dry enough for a flat coat before nav light, pitot and window painting to finish...
😆 🤣...yep a hanger would be a great idea for sure ....the main reason for the 35th scale choppers is ..well I do love aircraft where the earth rejects em and since all my armour is 35th and mods I want to do weapons wise is very easy .
Also I'm lucky that with some of the prices I've payed have been stupid low even compared to 48th .
That MD-500 might be doable dude..Academy do 48th T tail 500s with 4 bladed rotors and their damn cheap to ..building a 5 rotor head wouldn't be that hard at all ..ive built all of the versions Academy have ..they go together pretty damn nicely and scale out well .
If you really want a MD-500 which will do ya good..Kittyhawk does a Little bird in 35th ..which I have along with an original Dragon OH-6 which I got given to me ..am I going to do anything with that ?.. not anytime soon knowing how bad it is..hence why I got given to me  ;D
The Kittyhawk kit is very nice..comes with quite alot of goodies aswell and nicely molded ..there's also plenty of reviews on it out there too ...great for making up ones mind  ;)
Just did some hunting on the net cause my brain was thinking about the Academy MD-500 kits and yep the brain actually remembered something 😅
The 500 TOW Defender has a 5 bladed main rotor along with the  navel version, but that one has extended landing skids .
Things are looking up matey  :thumbsup:
Quote from: Wardukw on June 30, 2025, 12:44:45 PM😆 🤣...yep a hanger would be a great idea for sure ....the main reason for the 35th scale choppers is ..well I do love aircraft where the earth rejects em and since all my armour is 35th and mods I want to do weapons wise is very easy .
Guess i should've clarified... ;D  I have both Academy 48th kits you mentioned. I was only referring to 1/32 for the Blue Thunder helo builds. It's only because the Monogram Blue Thunder is 32nd scale so i wanted to build all 3 helos in the same scale.
In 1/48 it was easier to find both the Fujimi Jet Ranger and the Academy MD-500 but i never got a chance of buying the 1/48 Aoshima Blue Thunder kit so, if i ever try to convert the Fujimi 1/48 Gazelle i own into the Blue Thunder, the other two are already in my stash but, with a built 1/32 BT kit and another one in the stash, it's not very likely i'll change the project to 1/48.
BTW, i've just found that both the Jet Ranger's and MD-500's tall skids are available at reasonable prices from a German company. That means that i'll reduce the workload a bit with those two aftermarket parts.
I'll still need to make the 5 bladed rotor hub and the 5th blade, and modify the OH-6 kit's tail for the MD-500 and just a few mods to the Jet Ranger kit.
And then, either find aftermarket suitable figures or make my own like i did for Blue Thunder. :mellow:
Back to the Kiowa, gloss coat has been sprayed but it's so hot in my studio that i need the fan working to even be able to be in here and that sucks for airbrushing so, i will leave the flat coat for tomorrow and chill for the rest of the evening. Starting work at 6 a.m. during these hotter days does take a toll on the body, especially when i have to handle a lawn mower that weights almost as much as i do...   :rolleyes:
Well, this has finally been finished.. kind of...
The KV model mask sets aren't as good as i expected them to be because the time saved applying pre-cut masks is going to be spent trying to eliminate the glue residue left on the windows without breaking anything or pushing one of the windows into the fuselage... :banghead:
Even worse, there were areas where the glue came off the vinyl mask and the mask lifted, allowing the paint and varnish to bleed through... those areas will have to be carefully cleaned up with a bit of alcohol on a Q-tip. This means i'll only be able to get some decent photos sometime next weekend.
 :thumbsup:  :thumbsup:
Different manufacturers may be better but, of course, may not do the subject you're building.  ;)
Quote from: Old Wombat on July 08, 2025, 07:33:43 PM:thumbsup:  :thumbsup:
Yep, that's the case here. But i guess i'll choose the next masking sets more carefully and i'll just mask the simpler canopies/clear parts myself with good old Tamiya tape. For me, mask sets' biggest advantage is masking the wheels for airbrushing so i'll buy more, just from different brands that make them with normal kabuki paper or whatever it is.
#26
Quote from: NARSES2 on July 09, 2025, 05:38:03 AMLooks good  :thumbsup:
Thanks, Chris!  :thumbsup:
Lets see if i manage to clean up those windows without damaging the paint job or breaking something... :-\
#27
Well, got some better pics of the Kiowa after cleaning the windows as best as i could but as predicted, one of the front door's windows came loose but luckily, it didn't completely detach and i was able to shake it back into place and quickly apply some TET before it got trapped inside... I'm just calling it done and moving on.
"After the end of the Portuguese "Ultramar" wars in Africa with the 1974 Carnation Revolution in Portugal, the country's armed forces returned to their homeland in disarray and were in desperate need of restructuring and modernization.
In 1975, there were several proposals made by the top brass of each branch to acquire new equipment but the funds available for all armed forces weren't enough to allow the purchase of all the desired assets so, each branch would have to find cheaper alternatives and make do.
The Portuguese Air force(PoAF) came back from the war with the experience of battle-tested tactics using it's helicopters to quickly deploy and support army or marine infantry troops to specific locations, making them one of the most important combat vehicles used in Africa.
The types already in service with the PoAF included machines like the Sudaviation SA 3130 Alouette II, the SE 3160 Alouette III and the Aérospatiale SA-330 Puma but the Alouette II was scheduled to be retired from service the next year and the observation/reconnaissance duties it performed would have to be passed on to its replacement.
With the experience of using the Alouette III as a support gunship, combined with the knowledge of the tactics and results obtained by different countries' armed forces in similar conflicts around the world, the PoAF decided to try out a new type of helicopter for reconnaissance, scouting, and directing fire support.
In March of 1976, a request was sent to U.S. government officials and after a few months of negotiations, a deal was reached and the helicopters chosen to be evaluated would be the Hughes OH-6A Cayuse and the Bell OH-58A Kiowa. This initial evaluation process would take place in the U.S. and conversion training for type rating began in January of 1977, at Fort Rucker, Alabama, with two teams of 4 experienced pilots and 4 crew chiefs on each team.
The PoAF staff went back home after a month and were very enthusiastic about the capabilities of both types. Still, only one type could be chosen and the after all aspects were considered, the decision was made by the top brass to the procure an initial batch of 10 OH-58A airframes, 10 engines and spare parts kits, with the intent of acquiring a total of 30 airframes, to be delivered before the end of 1980.
Unfortunately, just a few days after the first batch had been delivered in May of 1978, the unstable political situation in the country led to large popular strikes demanding a reform of the country's national health system and education institutions.
This would result in the revision of the country's annual budget and end up with a larger reduction of the military budget, ultimately causing the cancellation the rest of the acquisition program for lack of funds.
Of the 10 airframes delivered, 6 were put into service with the Esquadra 552 - "Zangões" stationed at BA11 in Beja, but were quickly retired after just a couple of months and stored at OGMAs warehouses in Alverca, near Lisbon.
Almost a year later, in April of 1979, all of the airframes and respective spare parts kits were sold to the Spanish Army, who'd been using the Kiowas since the early 70s.
The Alouette III fleet, which still had a long service time left in them and would have to be enough to meet the Air Force's needs in peace-time operations, well into the 21st century."
So there it is, what was supposed to be a one week build turned into almost two months?...  :banghead:
Wanted to add pilot figures but in the end just made some seat belts with Tamiya tape kept it simpler.
The glue residue left on the clear parts was what one of the worst aspects of this build and i'm still debating if i'll ever use any of this brand's other sets that i already purchased... :-\
Regardless, the kit is not bad, just needs careful clean up of the parts before assembly and a bit of patience and planning to be able to get the clear parts in place with no glue residue and still have a strong enough bond to keep them from popping in while masking or simply handling the model.
I'd build more if i had them, especially the LAPD boxing, which has the taller skids and search light but these are now probably some of the rarest kits ever made by Italeri, along with the 1/72 YF-23 Black Widow or B-26K Counter Invader, for example. I'm hoping there will be a repop in the future so, i'm gonna wait... with any luck, someone comes out with a new kit in the meantime. :rolleyes:
I'm impressed! :thumbsup:
I refuse to build helicopters in anything other than 1/48 or 1/35 ... When I get around to building them. :rolleyes:
