avatar_Gondor
I thought I had been cured...
Started by Gondor, May 18, 2025, 01:12:30 PM
Filler, filing, prep work and drilling. That is what I have been doing today, at the cost of a 0.5mm drill bit;  :banghead:  the wings are ready to accept the new wingtips, though. First, the underside of the wings need lost detail rescribed into them, not something that I am the best at, although I think I might be getting a bit better at it.
I also found out that the conversion set has two sets of doors. One closed, and the other open, so when building one of the spare forward fuselages, I won't need to get hold of a spare set of undercarriage doors; I can use a closed set! In fact I think I only need to make an intake cover and then I can cobble together the rest of the covers, etc that I need  :thumbsup:
I'm a bit of an idiot, although some others' thoughts on that may vary, I still concede that I'm a bit of an idiot.
The reason is that I decided to remove some parts from their supports and test-fit them. Nothing wrong in that, you may think. However, you may change your mind when you realise that I was test-fitting the radome and everything is almost a very tight friction fit, and with the radome, you have nothing, and I mean nothing to get hold of to try and pull it back out once it's in  :banghead:
Test fitting the radome had not been a problem with the first build, especially when the forward fuselage had not been fitted to the rest of the airframe. Now, not so good an idea as all the fuselage sections are firmly glued together.
This may lead to plan B  :wacko:
Now, plan B involves one of the initial forward fuselages. This has had a cockpit fitted along with an intake trunking to make a forward fuselage section. I have also fitted a set of closed nose undercarriage doors, and am currently making up an intake cover to go over the front of the nose section. This will get part of an old From Lightning F.6 radome fitted into the centre of it to represent the P.8's radome.
I also managed to rescribe some panel detail to the underside of the wings.
It's not perfect, but it's on the underside and will do the job nicely.
Next up, I need to make instrument panels and fit the combing that goes over the top of them, it might also be a good idea for me to cut to shape one of the canopies so I can check that everything fits inside the cockpit. If all that goes well, then I will feel safe enough to add the undercarriage and wings.
scautomoton
if you pinch the sides of the nose the radome should just slip in and out easily
I had a quick go this morning, no luck, but then this is the latest version of nose with integral intake ducting, so probably not very flexible. Not a problem as the intake trunking was painted and I only need to paint the part of the nose that will be seen.
Slow to no progress most of this week. I did manage to get the wing tip launch rails fitted to both sets of wings.
0.3mm rod glued into 0.5mm holes. I allowed for the glue, but maybe a 0.4mm rod would have been better.
A bit of filler and a sliver of plastic card, and everything should look good. The other three are similar, but all fitted, which is the main thing.
I have been away to Inverness for a wedding, not mine, and have been mainly relaxing since I got back. Today though, I got a bit more work done. Three canopies have been cut away from the rest of the clear plastic to a standard of 'very close', which will allow me to ensure that I can get the interior parts checked for fitment while everything is separate parts. I have also been working on the main undercarriage legs. One set is assembled and ready to be fitted to the fuselage, the other set has been prepared ready to be assembled to the same stage.
I have also been finishing the fuselage, which I had previously added some filler to the rear join. That was also sanded back today, and the fuselages given a wash. They both need to be checked to see if any detail needs to be reinstated, and once that's complete, I can then add the undercarriage.
I really must get on with painting the ejector seats, or they will end up holding back everything.
Received today from @scautomoton, now Machina Models
This will be built in the future along with the AW.169
Further work has happened, just not a lot of it.
The cockpit display has made progress, so let's start this update with a big toothy grin
The small pieces of square plastic rod are to act as supports for the radome
The instrument panel coaming has also been started
I know it's not what was recommended by @scautomoton in the instructions, but as this is a display or a cockpit section that was rescued from the scrap heap, bits needed to be made to replace missing parts. That's my reasoning behind the scratch building of the coaming and any other disparity.
Further work was carried out today.
Dentures were fitted  ;D
and the opposite end of the cockpit was covered over
I tried to have some of the panels overlap, as it might have been done in real life.
Some came out better than others. Just the thin plastic card and a pair of parallel pliers, along with some imagination, were all that was used other than the glue to stick the parts in place.
So far today, I have been re-scribing panel lines on a fuselage that lost some of the detail while ensuring a smooth joint between fuselage sections. I then decided that it was about time to fit the fin!
So out with a jig to help keep everything upright.
Then, a check of the wing root to see if the fuselage is vertical
Looks reasonable, on to the fin.
To get to the above point was a pain. It was only when resizing other photographs that I found that the fuselage was not as vertical as the two parts that make up the exhaust tubes were not vertical. By that time, I had already added glue to the fin and fitted it in place. Good job I was using plastic glue! *PAUSE*
*RESUME* I just realised that the fin might be plastic, the fuselage is resin. I have just added superglue to the base of the fin/fuselage joint, in that some of the glue will flow between the two parts by capillary action.
Anyway, as you can see in the above photograph, the fuselage and fin are both vertical.
It's too hot to do anything other than sleep or melt. I have, though, managed to fit the wings onto the fuselage. It took a while to make sure that every part of the jig was symmetrical, but I got there.
The angle of the wings looks good too.
Progress is there, just rather slowly at the moment in this heat, which is 26 oC in the modelling room, let alone the rest of the flat.
26 is about 1/2 as much again as I find optimum,, so I Feel your Pain...
Good progress, though.
Quote from: Rick Lowe on July 12, 2025, 07:31:47 PM26 is about 1/2 as much again as I find optimum,, so I Feel your Pain...
Flippin' eskimos! :rolleyes: That's the temperature at which I start to thaw out! ;D
Quote from: Old Wombat on July 12, 2025, 10:01:36 PM
That... explains a lot, actually...  ;)
Slow progress, but progress nonetheless. Getting a bit distracted by the new P.1121 build, but this has not been forgotten. The vertical tail has been fitted to the second build. Work is ongoing to blend the new wingtips into the rest of the wing. Once that is done, then once they are fitted, both builds will be almost identical, so I can set up a jig to get the main undercarriage nice and level and the same between both aircraft, or at least as near as I can.
