avatar_killnoizer
Ju 388 vacu kit
Started by killnoizer, April 23, 2025, 01:47:35 PM
killnoizer
This evening i did a lot of sanding and work on the main part of the cancel.
Soften the clear part with the candle and cool it down on metal.
Good tools are to see in the picture 😵�💫
                     ~ π ~
VDPM Hannover / Germany
63cpe
Ehm, maybe a bit late to the party but I have vacuum formed reproductions canopies for 1/72 ju-288 and -388 available. The plastic is the non-yellowing type.
David aka 63CPE
killnoizer
Quote from: 63cpe on May 18, 2025, 12:06:33 AMEhm, maybe a bit late to the party but I have vacuum formed reproductions canopies for 1/72 ju-288 and -388 available. The plastic is the non-yellowing type.
David aka 63CPE
I have one in spare, thank you  :thumbsup:
but maybe you can show us some pictures?
Today i put the spinner parts together on a base plate of sheet, they fit exactly in the engines and i glued them together.
I found some props left over from a He 111z and cut the blades off.
The engines and the spinners together will be good to handle for the following work...
                     ~ π ~
Cool - coming along nicely. :thumbsup:
killnoizer
#50
:mellow:
This morning i could spend some time and work in a flow to fix all the 12 blades in one go.
For that i put a drop of classic glue on the blade and one to the counterpart at the spinner, let it stay until it is nearly dry, check that with the famous toothpick. Than put them together exactly as possible, a little turn and pressure and they will stay in a moment!
Think the engines looks like some powerful untits.
Good connection, need just a little bit of work later.
That was just one hour of work 😃 but a big step for the build. Now i need a good box to keep them without damage...
                     ~ π ~
killnoizer
The moment of truth ...  :wub:
I did a shower of silver spray over the fuselage and continue with sanding and more putty, what will continue with more sanding...  :rolleyes:
You know.
Time for the wings and tail.
                     ~ π ~
George the Cat
killnoizer
#53
Yesterday morning i found some massive mistake in my design.  The new made props were much bigger than the original size and would hit straight in the cockpit section  :banghead:
So i decided to make the wings bigger ( what is always a good idea  :thumbsup:  ) and generate some space for the rotating blades...
I cut some stripes out of a111z center wing and added them to the 188 wings, the operation went well and quick.
And added some panel lines on the new parts.
                     ~ π ~
Quote from: killnoizer on Today at 01:17:05 PMSo i decided to make the wings bigger ( what is always a good idea  :thumbsup:  ) and generate some space for the rotating blades...
 :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
MY kind of thought process there, oh yes!  ;D
killnoizer
Yes, i know that you would like that and got you in my mind 😀.
All the glue needs time to dry, so i have to wait for more work. Cockpit and clear parts should be ready before attaching the wings for better handling.
                     ~ π ~
