avatar_killnoizer
Yak 15 -3
Started by killnoizer, February 15, 2025, 06:23:48 PM
Fixed tricycle undercarriage with spats?
killnoizer
Quote from: zenrat on February 20, 2025, 04:05:45 AMFixed tricycle undercarriage with spats?
That thing looks much to fast for fixed legs, i made something like that on my Herford Bomber ...
But who cares about if it's standing on the ground,  just the rivet counters  😄 .
First theme is the main color ,  maybe some tiger stripes in green/black or only green .
The basic idea was a german Luft '47 aeroplane,  so it could be in german markings.
                     ~ π ~
VDPM Hannover / Germany
That's a really cool looking machine !
Quote from: Captain Canada on February 20, 2025, 06:58:31 PMThat's a really cool looking machine !
It certainly is. Mind you they look like stand off missiles in the engine pods  ;)
killnoizer
#19
They ARE MISSILES in the engines  :thumbsup:  .
I have added some fine lines, dirt and clear coat to the first Yak .
The second Yak i have will be a 5 engine version :
It is based on this unbelievable bad kit :
In fact it is the worst bunch of plastic crap i have ever seen .
                     ~ π ~
Quote from: killnoizer on February 24, 2025, 02:21:42 PMIn fact it is the worst bunch of plastic crap i have ever seen .
The Wooksta did warn you.  ;D  ;)
killnoizer
There is a lot of sheet added at the front to get it in shape,  at the tail i have removed much material for the same reason, both parts of the fuselage are different. It's a luck that they are nearly 3 mm strong so there is enough flesh for sanding it ...
The ZEN of model building 😖 .
                     ~ π ~
frank2056
If the name "Veeday" (Bidet) didn't clue you in on the quality... Looks about as good/bad as a Merlin kit or early Pegasus.
The 5 engine Yak looks interesting. The Soviets had the Su-10:
Your Yak sounds like a proof of concept.
killnoizer
Yes , the USSR has copied that from my early design book.
                     ~ π ~
And here I was thinking the Pioneer 2 Yak 15 was bad.  It's a treat compared to this.
Quote from: frank2056 on February 24, 2025, 10:00:54 PMLooks about as good/bad as a Merlin kit or early Pegasus.
They had a lot in common with Merlins, and not just the 'quality'
killnoizer
#26
Anyone watched ERASERHEAD by David Lynch ?
I gave here a short coat of silver and put the wings on .
                     ~ π ~
killnoizer
#29
... and continue :
the 5 engine got a tailwing some weeks ago.
And another YAK 23 is tuned by 2 engines build from 2 droptanks ( i don't know where they came from, giftet from a club member or so ) .
Cut them into 3 pieces and fix it together in another way .  And a lot of sanding .
Then ad 7-8 steel balls in the front, this will be a part of a little diorama, standing at the ground .
It is based on the very old KP Kit.
The exhaust is very simple but effectif.
                     ~ π ~
