My stash just grew again 2025
Started by Martin H, December 31, 2024, 08:53:54 PM
Why do you need a Mk II Lanc kit for the RAAF Lincoln Fred? Isn't it only the engines that differ from other Lancs?
And I just LOVE that Cyclone, and with a Cammer too! What's not to like? I didn't even know it had been re-popped.  :wub:
Quote from: PR19_Kit on November 20, 2025, 04:37:01 AMWhy do you need a Mk II Lanc kit for the RAAF Lincoln Fred? Isn't it only the engines that differ from other Lancs?
Blackbird designed the conversion set to use the Airfix B.II because its wider nacelles line up better with the Lincolns annular radiators.  They state that the B.I/III kit can be used but it would need more PSR.  I'm all for avoiding PSR where possible.
#1577
In desperate lack of construction time, I have, as usual, resorted to buying more kits. Makes sense, right? :rolleyes:
First - the Top Gun resin radar guided AIM-26B Falcons, known as Rb27 in Sweden. A catch, really! A Hasegawa AIM-4F/G is shown together with the bigger AIM-26B below to show size and differences/similarities.
Taking inspiration from Thomas, a Vautour to be rebuilt into a SAAB Lansen alternative. I am looking to use SAAB wings, canopy and maybe some other things, but differing from Thomas's impressive project, I plan to stick to the tandem seating.
And moving just a few years back in time, the what-if jet SAAB B-18 I found triggered me to catch this old Do-217, planning to combine it with an already in-StashTM Ilyushin Il -28 and perhaps some more SAAB parts.
Also, a spare Lansen and yet another Hasegawa Draken went my way as they were sold surprisingly cheaply by the same seller from which I acquired the Rb27 SARH Falcons.
Further, a Nord Noratlas mainly bought because it has the big decal sheet, containing Portuguese and Greek machines in addition to the ubiquitous French and German ones. Plus, it came cheaply. I fear people these day's doesn't properly appreciate the niceties of a Heller kit.
And lastly, an old Su-7BPK, procured to provide a fuselage for a single engine E E Lightning alternative. It has been done before, but not by me. And I already have a Hasegawa Lightning F.6 that will supply wings, tail fin etc etc.
Now to find time to actually do some modelling...  :angel:
You really need two Su 7 fuselages - the EE P6 doesn't have that area rule bulge, although the proposed Olympus one *might* have done - doing a cut and shut in the middle.  That was the one I did, although Thorvic kindly supplied the fuselages pre done.
Mine just taped up
And with the cockpit in, showing the stiffeners where the two fuselages were joined.
It was intended to be a resin conversion, although I couldn't at that point (2005?) work out how to mould it.  Now, having gained the experience, I can, but undoubtedly some show off with a 3d printer will do it first.
And the wing is shoulder mounted, as opposed to mid mount on the Su 7.
Quote from: Pellson on November 20, 2025, 05:43:01 AMa Vautour to be rebuilt into a SAAB Lansen alternative
That sounds ...interesting!  :thumbsup:
Quote from: zenrat on November 20, 2025, 05:02:31 AMBlackbird designed the conversion set to use the Airfix B.II because its wider nacelles line up better with the Lincolns annular radiators.  They state that the B.I/III kit can be used but it would need more PSR.  I'm all for avoiding PSR where possible.
Ah, thanks, I didn't know that about the nacelles, but it makes lots of sense, especially avoiding the blasted PSR!
Quote from: Pellson on November 20, 2025, 05:43:01 AMAnd lastly, an old Su-7BPK, procured to provide a fuselage for a single engine E E Lightning alternative. It has been done before, but not by me. And I already have a Hasegawa Lightning F.6 that will supply wings, tail fin etc etc.
I approve of any and all single-engined Lightning-Sues, having done this one back in the day:
https://www.whatifmodellers.com/index.php?topic=34972.msg555660#msg555660
Received today
1 x 1/35 Takom 2026 Chieftain Mk.11
1 x 1/72 Airfix Club A73015 Limited Edition Gloster Meteor FR.9. Bought for the rockets, which will go to a Reaper as the bits and are in another box which has been marked up to become the Reaper.
Quote from: The Wooksta! on November 20, 2025, 05:59:44 AMYou really need two Su 7 fuselages - the EE P6 doesn't have that area rule bulge, although the proposed Olympus one *might* have done - doing a cut and shut in the middle.  That was the one I did, although Thorvic kindly supplied the fuselages pre done.
Mine just taped up
Dont you mean two Su-9 Fishpot, thus the blue plastic !!! the Modelsvit S-32 might wotk as that doesnt have the area ruled bulge.
It's been that long since it was passed along - twenty years? - I'd forgotten what the base kit was.  However, IIRC the only difference between the Su-7 and Su-9 is the wing, the fuselage remains the same.
Quote from: Weaver on November 20, 2025, 11:00:48 AM
That's the one that first gave me the idea. A simple, yet effective conversion. A masterpiece in my book.
Quote from: Thorvic on November 20, 2025, 02:31:25 PM
Mine just taped up
In reality, the Su-7 and Su-9 fuselages are not exactly similar, but close enough to pass unnoticed in 1/72.
Regardless, this model is perhaps even more impressive due to its increased complexity. However, that might be why I'm looking more towards Weavers' build, as I'm a firm believer in the KISS rule, and not only applied to one's loved one, as it happens.
F.i, I am not planning to move the wing attachment to the shoulder. While the two-engined Lightning appeared as such, one could argue that it is in fact a midwinged single engined fighter with a second engine added below the first one. And that logic will do for me.
For now, however, I'll try to first complete a few Draken builds. Not much left, really, but the outside world keeps interfering badly.
There can never be enough weird Lightning variations...  ;D But modding one into a single-engine version is already quite a stunt.
Quote from: Dizzyfugu on November 21, 2025, 12:23:37 AMThere can never be enough weird Lightning variations...  ;D But modding one into a single-engine version is already quite a stunt.
I think you're yet another culprit in this ongoing crime, Thomas. Right?
>>English Electric P.6/1 "Levin"<<
Yes, I can speak about personal experiences in this sub-genre.  ;)
Quote from: Pellson on November 20, 2025, 11:20:22 PMThat's the one that first gave me the idea. A simple, yet effective conversion. A masterpiece in my book.
Why thank you, you're too kind. Truth to tell it's a bit rough around the edges, but then it was thrown together in a week for a show deadline after the original build had a paint malfunction.
Quote from: PellsonIn reality, the Su-7 and Su-9 fuselages are not exactly similar, but close enough to pass unnoticed in 1/72.
Note that the one I used was the VEB Plasticart Su-7, which I think is significantly over-scale. I can definitely say that I've got other brands of Su-7 and they appear skinnier. This may mean that the exact conversion techniques I used on mine won't work on yours, so be careful and triple-check everything before committing to glue.
Note that Lee and I were trying to do rather different things. He was trying to make an accurate model of the real EE P.6/1 project, while mine was wholly fictional (I called it the "P.7D Thunderbolt") and driven by considerations of what was quick, easy and low-risk to do in the limited time available.
Good luck - I'll be watching with interest.
