avatar_Wardukw
The Viggen Plus ...DONE!!!
Started by Wardukw, October 07, 2024, 03:28:55 PM
Quote from: kerick on October 10, 2024, 07:55:22 PMHmmmm, F-105 intakes on the Buccaneer or the twin engine Viggen? Or both? Viggen intakes on the F-105?
I'm not helping am I?  :wacko:  :thumbsup:
A couple of the guys at my model club think I'm a bit strange. I like that. 🤪
Strange is a understatement Ken ..I say that cause all of a sudden as I was trying edit my last post the site went stupid weird..it kept adding to the post ..it would copy and paste the same thing even tho I removed it  :o  :o
It's all good now 🙂
No not helping 😆 😂 🤣
But it's help I like 👍
I have noticed tho you keep taking parts from bloody expensive models I don't have too  ;D
Tho the Buccaneer intakes idea is also ticking away  ;D
You could use pipe as the base - something from a hardware shop, with some filler (or another short length mounted over it and filed to shape) on the outside to create the right curvature.
Or some of those halloween toys from a $2 shop - the scythes and whatnot; the handles are close enough to styrene, to glue with model cement.
The inner curves could be cut off and reversed, as has already been mentioned. Or just mount them straight to the fuselage and dummy up the splitter plates.
All ideas are useful; if not for the current build, they can go into the 'idea bank' for future use - with or without modification.  :thumbsup:
This shows how great my memory is these days ..I just remembered I've got 3 F-15s  :banghead:  :banghead:
Which had me wondering how bad an idea it would be to mount F-15 intakes on a Buccaneer  :wacko:
PSR part 1 done ..
PSR part 2 has commenced  ;D
Seems my first bit of putty work sucked 😕 😬
Quote from: Old Wombat on October 10, 2024, 05:01:57 AM
Quote from: zenrat on October 10, 2024, 03:28:38 AM
Quote from: Wardukw on October 10, 2024, 02:17:10 AM...what the hell would to do to wiff a Buccaneer? ...
Good question.  Something which has been puzzling me also.  Albeit thinking in the one true scale.
So, you're coming around to our way of thinking, then? :wacko:  :wacko:  :wacko:
Heh heh heh.
No.  Dream on.
Quote from: Wardukw on October 10, 2024, 09:12:55 PMThis shows how great my memory is these days ..I just remembered I've got 3 F-15s  :banghead:  :banghead:
That would be a strange one! I like it! Mounting the rectangular intakes on the rounded body of a Bucc would be a challenge.
Zero-Sen
#37
Quote from: kerick on October 11, 2024, 07:17:56 AM
Well this is quite possibly on the drawing board now Ken 🤔
I know where there's a Buccaneer for sale which is already made ...so we'll see next week how that goes  ;D
Quote from: Zero-Sen on October 11, 2024, 08:50:50 AMMirage IV intakes ?  :wacko:
Yeah not like that's bloody near impossible to find in 48th   :wacko:  :lol:  :lol:
And again ..PSR session 2 is now done .
Session 3 is underway and I'm trying this Ammo putty to see how it goes...im interested to see how it compares to Tamiya putty.
I quite like the Revell putty - doesn't shrink like the Tamiya.
I've used Bondo spot putty for years. It will shrink if I put it on thick but that's usually stage 1 of PSR anyway.
Quote from: Rick Lowe on October 11, 2024, 07:11:43 PMI quite like the Revell putty - doesn't shrink like the Tamiya.
My only issue with the Revell putty, and to a lesser extent with Humbrol, is the amount of solvent that seems to collect at the top of the tube and which you need to squeeze out until you can use it.
Quote from: NARSES2 on October 12, 2024, 04:52:55 AM
That's the one thing I do love about Tamiya putty..there's zero of that ...if it would stop bloody shrinking it would be prefect.
Quote from: Wardukw on October 12, 2024, 11:26:51 AM
I think for my next tube of Revell I will use a toothpick and stir it about a bit first.
Yeah, the shrinking is the reason I went away from Tamiya.
Presto, think PRESTO!  ;D
Ask Dizzy which putty he uses.............  ;)
Its does shrink but not very much, and there's ZERO liquid component to it, just don't try and buy any in the UK as no-one sells it.  :banghead:
Not something we can get here, either.
