avatar_Spino
USN/USMC Superprops
Started by Spino, October 01, 2024, 03:22:46 PM
Spino
Quote from: kerick on October 16, 2024, 10:15:14 AMThese ideas are interesting. I'll have to investigate a little more and see how that would fit a Corsair, Skyraider or Black Widow.
Actually a Black Widow with Pythons would be interesting.  Or an A-26 with T56s.  I could see an upgraded A-1 with a T56, or a British version with a Python (instead of the Wyvern).  Once I get finished with this project and another kit that was recently gifted to me, I plan on doing an A2D Skyshark (yes, gotta have that unreliable T40 on something  ;D ) or maybe an A2J Super Savage.  I wonder about a Firebrand fitted with the Python, though that would make for a really long nosed plane.
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
perttime
Perhaps there's a kit, somewhere, for XP-61E or F-15 Reporter.
There is, I can actually see one from where I'm sitting actually.
Mine is an Anigrand resin but there's a good vacform F-15 too as I have one of them in The Loft.
Looks cool! Lots of whiffery potential.
Spino
I could certainly see a couple of Wasp Majors on there!
Regards, Spino
Spino
I'm trying to decide what to arm the Bearcat with.  It has three pylons for heavy stores (~1000lb each) and two for lighter ones (~500lb each).  I'm thinking a combination of M-117 bombs and Zuni rockets (twin pods).
Regards, Spino
Quote from: Spino on October 19, 2024, 08:06:10 PMI'm trying to decide what to arm the Bearcat with.  It has three pylons for heavy stores (~1000lb each) and two for lighter ones (~500lb each).  I'm thinking a combination of M-117 bombs and Zuni rockets (twin pods).
M-117s and Zunis ...with the brutal look of your bird and bombs and rockets..a very nice mix 👌  ;D
Spino
Well, I'm going to have to scrap the twin Zuni pod idea, it's just too small to play well with an FDM printer like mine.  Maybe if I had a resin printer  :banghead:
I may break down and buy one some day, but for now the FDM will have to do, and I will have to use the traditional LAU-10 quad-shot pods.  Oh well, more firepower is fine with me  ;D
Regards, Spino
Would styrene tubing and sharpened kit runner do the job?  :unsure:
Spino
Quote from: Rick Lowe on October 20, 2024, 09:48:09 PMWould styrene tubing and sharpened kit runner do the job?  :unsure:
Maybe if I had that stuff on hand.  After checking the weights I think I'll just print some LAU-10s for the inner wing pylons and maybe a couple of Mk-82 Snakeyes for the outer ones.  I'll probably also hang an M-117 on the centerline.
Regards, Spino
Quote from: Spino on October 21, 2024, 09:39:40 AM
Don't forget the fuse extender if you're going for early 60's look. It's just a pipe in place of the regular fuse with the fuse on the tip. Should be easy to print.
Spino
Quote from: kerick on October 21, 2024, 04:35:43 PM
I doubt it would be that easy to print, I used to have a Revell F-105 that had a couple of those on its center M-117 rack.  I'd probably be better off to drill a hole in the nose of the bomb and glue in a small piece of wire.  That would also be less likely to snap.
Regards, Spino
Spino
Well, I think I may be able to salvage the twin Zuni pods after all.  I had printed some HVARs with fins that didn't turn out so well, and only the nosecones of the rockets in the Zuni pods were messed up, so I think I can cut off that part and replace it with a pair of HVAR noses.  No one will ever know  ;D
The Turbo-Bearcat has its first coat of paint applied, sky grey on top and white underneath.
Regards, Spino
