avatar_buzzbomb
Side Projects - M20 Greyhound and British Weapons Carrier
Started by buzzbomb, July 22, 2024, 11:15:01 PM
Jakko
It looks very good, but I have one criticism about the camouflage on the mortar carrier :) In addition to the dark colour coming down from the roof, you also need to make it go up from the lower part of the vehicle. The purpose of this style of camouflage was to darken the areas that catch the light and blend them into the vehicle sides (which you did quite nicely), but also to add dark paint around the areas that would be in the shade to also blend them into the sides.
Basically, spray more dark paint around the wheel wells and the lower sides, but not into the wheel wells themselves, under the mudguards, under the overhangs of body and cargo bed, etc.
Found something else shiny to work on, so finally putting this on the shelf
Quad Weapons carrier - Mortar
6th Armoured Division - Motor Battalion Support Company - Italy 1942
That's some phenomenal work ! Thanks for taking us along !
Either I'm loosing it or if there is a pic I'm going blind cause I ain't seeing nothing  :o
Quote from: Wardukw on August 25, 2024, 02:39:49 AMEither I'm loosing it or if there is a pic I'm going blind cause I ain't seeing nothing  :o
There are four photo's & the build is BT's usual excellence! :thumbsup:
Quote from: Old Wombat on August 25, 2024, 08:08:02 AM
Patience, it takes a while for the electrons to get all the way to NZ!
Quote from: NARSES2 on August 26, 2024, 05:40:40 AM
Quote from: kerick on August 25, 2024, 08:11:01 AMPatience, it takes a while for the electrons to get all the way to NZ!
 ;D  ;D
They have to be stopped and inspected at Customs/MPI; and as they are shedding staff these days, it'll take a wee bit longer from now on...
The problem is we're so small the bloody signal can't find us ..then the signal does a looksie about until it finds us ..two days this time around 😴  :o
