Ricks' Ramblings
Started by Rick Lowe, July 20, 2024, 06:33:31 PM
1/72 Mustang 1a RAF **Real World**
Back in the mists of time, I acquired an old, assembled FROG Mustang.
It was pretty rough and I tried to fill a hole in the wing with tube glue.
That didn't go so well, and when I found it had bowed - a lot - I was ready to bin the whole thing.
But I hung onto it because, well... I don't like binning kits.
Later, when I realized there was no other Allison-engined Mustang on the market (at least not at that time), I decided I should do something with it.
So, I hacked the nose off and attached it to a Monogram kit.
A scratchbuilt cockpit and then the belly scoop was cut off and replaced with one built up from plastic card.
20mm cannons were made from a Matchbox M-16 kit's gun barrels inserted into tubes.
Because the 20mm wing ammunition access panels were different from those of the .50-armed versions, I went to the extent of sanding off the raised panel lines and rescribing the whole model; in the end only some of them are still visible under all the paint...
The FROG spinner was used along with a propeller from a P-40.
And there she stalled for a good few years (that was a bit of a theme that developed at that time...).
I eventually pulled it out again (along with the Cavalier Turboprop) and we were away again.
Perusing the references I saw they were mostly used as Photo-Reconnaissance birds, so I removed the radio shelf and scratched up a camera to fit there instead.
I carefully and trepidatiously punched a hole in the Falcon/Squadron canopy - whew! in the right place and everything lined up – then installed it and filled the gaps around it.
Landing gear from spares as the originals had disappeared over time.
Main paint scheme is Model Master enamels brushed on; I masked for the rear tail band then painted that and the spinner Humbrol Sky.
Markings are spares box, to depict aircraft FD472:M of 168 Squadron RAF.
You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
And a couple more
Nice work, Rick!  :thumbsup:  :thumbsup:
I prefer the Malcolm hood mod's myself.  ;)
Quote from: Old Wombat on June 21, 2025, 02:35:28 AMNice work, Rick!  :thumbsup:  :thumbsup:
Totaly agree with both of the above comments.  :thumbsup:
Thanks, folks.  :thumbsup:
Quote from: Old Wombat on June 21, 2025, 02:35:28 AMI prefer the Malcolm hood mod's myself.
Yeah, me too - but this is what is looked like in the photos and artwork, so...
Next time, though...
#458
Fokker D.XXI *Real World*
Pre- and early-WW2 Dutch fighter.
The old Pioneer 2 kit.
Got as a freebie at the club, once upon a time. Thought it'd be a quick build to keep the momentum going, and to take part in the Build the Same Kit competition it went with.
I made a rudimentary cockpit and detailed the gunsight a bit. Added a radio aerial and tailplane wires.
Paint is Humbrol.
Markings: I wasn't keen on the orange neutrality triangles, so I looked for something else.
I found some Czech roundels in the spares box and painted an orange dot in the centre. Tail stripes are painted.
(yes, there are a couple of shots sans prop - I forgot to reinstall it and couldn't really be bothered to retake them. Use your imagination)
You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
Very nice Rick.  :thumbsup:
Great work with the dot on the Czech roundels.  :drink:
Always liked Dutch aircraft of that period, if only for camouflage. You've done a neat job with that old kit. If you fancied a modern one, then the MPM kit is really nice.
Quote from: PR19_Kit on June 29, 2025, 01:00:22 AMGreat work with the dot on the Czech roundels.  :drink:
Indeed  :thumbsup:  :thumbsup:
Saw the pic's & thought you'd like this, Chris.  ;D
She looks pretty good to me!  :thumbsup:
Thanks, folks.
Yeah; the kit is a bit basic, but not unbuildable.
The cam is interesting, true enough. IIRC I only had the top and one side, so had to wing it (sorry) for the other.
Not something I'm looking to re-do, it was more to take part in the competition and have a bit of fun.
