avatar_zenrat
McDougall Donald F-45 Pheagle. Finished pics pg 8.
Started by zenrat, June 08, 2024, 03:38:01 AM
Quote from: NARSES2 on August 09, 2024, 06:32:30 AM:unsure:  Is this where people bring in a package they want to post but it has an existing bar code on it ? I'm confused. Not sure if Royal Mail/The Post Office here in the UK offer the same thing.
They're so public spirited they'd just reject such a parcel out of hand!
Quote from: zenrat on August 09, 2024, 04:57:23 AMAlthough I do use a big fat stinky texter (marker pen) at work to redact bar codes on reused packaging.  That has a heck of a kick to it.
Yes.  Someone might recycle a box or bag but not cover up or remove old labels.  If left readable the parcel could end up back with the sender.
They tend not to react favourably to this even though its bleedin' obvious it might happen if you leave the old labels visible.
Clothing is usually packed in plastic bags and we tell people "turn the bag inside out when reusing it - it puts the old labels inside".
"Oh wow, that's so clever" is a common response.
"No, its common f**kin sense" is what I want to say then...
Thanks. Next time I'm in our local PO I'll ask the ladies if RM will accept re-used packaging like that. Can't see why not, but I've never thought of doing it. Now I'm a pensioner though  :angel:
Quote from: zenrat on August 10, 2024, 06:32:17 AMClothing is usually packed in plastic bags and we tell people "turn the bag inside out when reusing it - it puts the old labels inside".
That's the sort of responce you leave until the day of your retirement  :angel:
To be fair, sometimes something is so blindingly obvious or simple, we miss it. I Know This Now...
Pheagle now has Sidewinders mounted under the intakes.
But...
...I realised there was space for a pair of Sparrows (it'll be "caricato per l'orso" as they say in Abissynia).  Painting is underway.
Are you sure they don't say "ለድብ የተጫነ" (Ledibi yetech'ane) ? :unsure:
Depends who is saying it.
Back story will make it clear(ish).
BTW, my translator renders the Amharic as ለድብ ተጭኗል (ledibi tech'inwali)...
Quote from: zenrat on August 11, 2024, 04:57:16 AMDepends who is saying it.
Mine did, too, but by clicking on it I discovered that the literal English translation of that version of the Amharic means "Installed for the bear", the version I have used is the literal Amharic translation of the English term you wished to use. ;D
Quote from: Old Wombat on August 11, 2024, 07:33:59 AM
Ya'll go right ahead with that! I'll be right over here, hopefully painting something today.
Sparrers painted.  Just need to be cleared and attached and then this is ready to go.
Quote from: kerick on August 12, 2024, 04:59:31 AMWhat's a sparrers?  :o
"Sparrers", sometimes written "Sparras", are Sparrows, generally referring to the avian variety, however, in this instance, I believe the term is referring to the AIM-7 medium-range semi-active radar homing air-to-air missile.
Quote from: Old Wombat on August 12, 2024, 05:17:36 AM
I suspected as much. Why else would you paint a cute little birdy? Or AI strikes again.
It's a 'Saff Lunnon' Brit-accent thing... Innit!  ;D
