Spitfire F25
Started by PR19_Kit, April 25, 2024, 08:54:46 AM
Scotaidh
I knew a guy who used to tear a piece of cardboard on all four sides - different profile on each side - then use that to mask his rattle-can spraying.  He would hold the cardboard about 1/4'' above the surface to allow the over-pray to make the soft edges he liked.  Quite effective.
Sure that works, but I'm a dedicated brush painter.
Quote from: The Wooksta! on October 26, 2024, 09:14:52 AMI don't see the point of masks if you're painting freehand.  Just more complications at a time when you don't need them.
Tend to agree Lee, but I can see Kit's point about giving them a try.
Must admit I've read some "horror" stories re vinyl masks, mainly about sealing the edges.
Quote from: NARSES2 on October 27, 2024, 08:02:32 AM
Kit I swear I've seen pics of Spitfires with those tanks ..very similar to ones fitted to Mosquitos ..when and where I saw em tho is a whole different story ..but I think Lee is dead right ..there ferry tanks  that I'm pretty sure off.
Chris ..vinyls can be hit and miss for sure ..thickness seems to be one problem.
I've used the very thin ones which will contour to shapes much better and they seem to also stick better ..the annoying thing is that some brands also tear to damn easily to and then the swear words start to fly.
German markings with stencils can be a nightmare..this I know all to well  :banghead:
I enlarged the painting diagrams from a set of kit instructions to 1/72 nd scale once and used thick tape to hold the edge above the surface to get a soft edge. Worked pretty good.
Top Notch have offered to send me a replacement set, which sounds good, but I can't help wondering what my current set was meant for.  :-\
mat
Quote from: Wardukw on October 27, 2024, 07:23:48 PMKit I swear I've seen pics of Spitfires with those tanks ..very similar to ones fitted to Mosquitos ..when and where I saw em tho is a whole different story ..but I think Lee is dead right ..there ferry tanks  that I'm pretty sure off.
Is it this kind of tanks, you have in mind?
Quote from: mat on October 28, 2024, 05:46:21 AM
Those are fairings for cameras as it's a PR bird. Close though
They're a lot deeper than those, and as Gondor says, that's a PRXI which carried all sorts of underwing add-ons, but their over-load tanks were always the belly type tanks, some VERY deep.
No, it's a PR1C.  You can tell by the smaller oil cooler and the shorter nose, plus the codes LY and the early style roundels which none of the PR.XI carried.
Nice photo, btw, not seen that one before.
IIRC, I might have added some of those tanks in the box of bits.  There's a lot of Spitfire and Spiteful bits in there, most of which I can't remember what.
Quote from: The Wooksta! on October 28, 2024, 07:28:20 AMNo, it's a PR1C.  You can tell by the smaller oil cooler and the shorter nose, plus the codes LY and the early style roundels which none of the PR.XI carried.
Blast, that's what I meant, a PR1 of some sort, sorry.  :banghead:
I've not seen that one before either, they're still coming out of the ground!
Not those matey ...the one I'm thinking of is mounted under the fuselage in between the landing gear but there's also these tanks which mount to the wings and there pretty distinctive in there appearance 😀 😉
I'll Blu-Tak the Seafire tanks in place so you can all see what they look like, they're pretty deep.
Quote from: Wardukw on October 28, 2024, 04:45:08 PM
The deep tanks you are talking about went out of use on fighter versions once the fighters became fighter-bombers and had a bomb crutch on the centerline. Once they had those they could only carry a cylindrical fuel tank in that position.
