avatar_killnoizer
He 111x , America Bomber ?
Started by killnoizer, March 14, 2024, 02:51:57 PM
Quote from: PR19_Kit on March 19, 2024, 02:48:36 AMThe stretched He-111 fuselage idea works VERY well in this context. Matching it with Tu-95 wings of a different scale is the work of genius!  :thumbsup:
I have to agree. It just looks right  :bow:
killnoizer
Quote from: Gondor on March 19, 2024, 05:54:00 AMBut will the wings take the strain of the dive bombing requirement that the RLM will force onto the aircraft designers?
Yes , they are planned as a one way kamikaze mission , so dive bombing is possible with this  :wub:
                     ~ π ~
VDPM Hannover / Germany
killnoizer
I need to complete the fuselage today , so i put the parts together . For a better connection i spread the backside a little bit to fit into the front part  .
If you doe this you should have some more attention for the direction of all the lines , so it went straight from every angle .
                     ~ π ~
killnoizer
I spend some time for sanding this morning , free day for me and with the sun coming out of the clouds a perfect spot for some model zen thing ...
I found a very cheap and fast drying putty from a german car supply , so i got the second layer on the plane now .
Also the place for the wings is in progress , the original 111 wings are VERY thick at the base .
Sorry, no pix .
                     ~ π ~
killnoizer
The shape is coming strong in this ...  :wacko:
I like that thing !!
Third layer of putty is applicated .
I found out that the props of the 95 in 1:144 scale are to small , so i have to build 8 Props by Hand .
Only 32 blades to made ...  :wub:
                     ~ π ~
Quote from: killnoizer on March 20, 2024, 08:37:43 AMI found out that the props of the 95 in 1:144 scale are to small , so i have to build 8 Props by Hand .
I admire your patience and perseverance sir  :thumbsup:
loupgarou
Quote from: NARSES2 on March 21, 2024, 02:26:40 AM
INDEED ! I'd be raving mad before half job.
Get the vintage VEB Plasticart 1:100 Tu-20/95 kit: it comes with four quite delicate (but working) contraprops, the blades can then be cut back to your needs . The kit frequently pops up at ev!lbay and can be found for just EUR 5,- if you are lucky.
killnoizer
Quote from: Dizzyfugu on March 21, 2024, 08:36:27 AMGet the vintage VEB Plasticart 1:100 Tu-20/95 kit: it comes with four quite delicate (but working) contraprops, the blades can then be cut back to your needs . The kit frequently pops up at ev!lbay and can be found for just EUR 5,- if you are lucky.
I found them only for bit more value ... That would be perfect , i wanna have a look at that .
I have build the kit in 1979 .
                     ~ π ~
killnoizer
Today it must be the first color , just for a better look at my mistakes ... :wub:
And sanding again , tomorrow.
                     ~ π ~
killnoizer
Hey Dizzy , the old VEB Kits are in production again  , we can get them brand new !
Check this site ...
https://www.reifra.de/online-shop/spielwaren-aus-eigener-herstellung/modellbau/bausaetze-fuer-flugzeugmodelle/
                     ~ π ~
That's an interesting site! I did a double take at the Buran. Whiff possibilities there!
killnoizer
The wostok ship is also very good !
                     ~ π ~
killnoizer
I started the production of the props today ,  think i spend the club meeting next week to finish that ,  and more and more sanding on the fuselage to get a real smooth surface .
                     ~ π ~
