avatar_chrisonord
AVRO kittleton. B.Mk1.
Started by chrisonord, March 06, 2024, 03:13:49 PM
Quote from: PR19_Kit on April 12, 2025, 11:10:36 AMThat's going to be one BIG machine when it's done Chris.  :o
It certainly is, I am going to have to hang ot from the ceiling in my model room. It takes up 3 quarters of my work bench too, so I can't tinker with anything else whilst it is on it.
Surprised me by just how big it is
That's bloody impressive work and an impressive build ...lovin this Chris  ;D  ;D
Quote from: Wardukw on April 17, 2025, 01:55:56 AMThat's bloody impressive work and an impressive build ...lovin this Chris  ;D  ;D
Thankyou Phil, I need to get some more motivation to finish it, as it isn't far off now. I also need to put some hangers up on the ceiling for it too.
George the Cat
Shades of the Victory Bomber that Barnes Wallis proposed.  :thumbsup:
Quote from: George the Cat on April 17, 2025, 02:46:03 AMShades of the Victory Bomber that Barnes Wallis proposed.  :thumbsup:
Just what I thought too Trevor, but the other way round.  ;D
Quote from: chrisonord on April 17, 2025, 02:38:19 AM
I'd recommend shark fishing cable 😀 😄
That'll be strong enough 💪 🤣
Well I'm thinking the most us lot yap about this the more you'll get motivated  :thumbsup:
Quote from: Wardukw on April 17, 2025, 12:01:19 PM
I have some 150lb flourocarbon for Conger Eels, and some titanium wire that is similar breaking strain. Should be ok if I double it up.  ;D  ;D
Quote from: chrisonord on April 18, 2025, 03:39:28 AM
Oh that will so work mate ..but only just  ;D
Now it's the structural reinforcements to the roof framing needed  :wacko:  :wacko:
Quote from: Wardukw on April 18, 2025, 11:58:13 AM
That could get expensive, so I thought ahead, and put batton around thentop of the walls, and put screw in loops into them. Fingers crossed that will suffice, as I have a 72nd scale TU 160 to go up there too.
Quote from: chrisonord on April 18, 2025, 12:13:49 PM
Already got a plan in mind 😌 😎
Just involves a few lengths of 2x4s and some long
coach screws  :thumbsup:
Oh or some long 5mm thick screw in eye bolts ..screwed straight into the roof studs ..oh we'll get ya  sorted  ;D  ;D
Those could take the weight of a 48th B1 Lancer  :thumbsup:
Quote from: Wardukw on April 18, 2025, 12:58:24 PMOh or some long 5mm thick screw in eye bolts ..screwed straight into the roof studs ..oh we'll get ya  sorted  ;D  ;D
I have a 72nd scale B-1 too, and would.have hadnanTU 95 too had I not sold it to Kit. Almost forgot about the Argosy.
Quote from: chrisonord on April 18, 2025, 02:41:57 PM
Yup..2 x 4s minimum 😆
Ya could get away with 2x3s up if it's like it is here..2x4s are cheaper  :thumbsup:  :wacko:
Lucky you don't have that 72nd An124 ..you'd need steel  ;D
