avatar_chrisonord
Fairey Delta 2 radar fit.
Started by chrisonord, February 10, 2024, 01:35:45 PM
That sounds like a good plan too Lee, unless I just put sidewinders on it or an underfuselage pod with a radar in it and firestreaks.
I used a long Hunter tank as a conformal tank underneath.  There's photos of it and an accompanying article in one of the Sig newsletters from 2022.  Don't recall which one though.
Quote from: The Wooksta! on February 12, 2024, 01:16:56 PMI used a long Hunter tank as a conformal tank underneath.  There's photos of it and an accompanying article in one of the Sig newsletters from 2022.  Don't recall which one though.
Did you use that as a fuel tank or a radar pod Lee?
Fuel tank.  As I said, the model had the original kit nose, the back story said it was a fighter used as a range target and the nose section too far gone to restore, so they used a research aircraft nose donated by a collector.
Iirc I added a few vents, blisters and a fin tip warning radar.  I never did get round to fitting the Firestreaks.
Quote from: The Wooksta! on February 12, 2024, 03:33:35 PMFuel tank.  As I said, the model had the original kit nose, the back story said it was a fighter used as a range target and the nose section too far gone to restore, so they used a research aircraft nose donated by a collector.
I see, I have ordered a.milan nose for mine and hopefully, I can get it to fit without too many problems.
October
