avatar_killnoizer
B17 XCD , advanced Flying Fortress
Started by killnoizer, January 19, 2024, 11:21:08 PM
killnoizer
Dear PR19 , and Zenrat , Kerick and Buzzbomb , thank you very much  :wub:
That cutting and sanding needs only MUCH time and endurance, and a sharp eye...  Things i needed in my original work over 40 years so much .  But how much work would it be to do that conversion with sheet and putty ?
This is the absolut last part to close the tailwheel bay :
It is not absolut perfect , but enough 😜
The very old vintage files from my Grandfather and dad are the best tools for that . They are super sharp and give a amazing smooth result , i have used No sanding paper for the complete Work, only for the wing bases to get the perfect fit:
The Boneyard .
I bought the two kits each from 15-19€ , that is a good Investment for the fun .
And i have a good pair of 4 engine wings left to build another STRONG Ju188 , or maybe a He111 ?
                     ~ π ~
VDPM Hannover / Germany
AMAZING work there, MOST impressive.  :thumbsup:  :drink:  :cheers:  :party:
killnoizer
#32
I made a construction of the props, i think this is the thing to come ..
Each blade around 8x12 mm , 12 pcs. per section .
It is just a short simulation , not 100% in measure ( but very near at the real size ) .
Front view of the first and the last rotator .
Later this evening i cutted the lines of the rotators and put a little bit black color in .
Next step is maybe building a tool from metal tubes to shape the blades with heat.
I think a 1" inch tube fits perfect into 1 1/8 inch tube , this could maybe solve the problem .
                     ~ π ~
Wow. That's summing up what I'm thinking. So cool !
This caught me by surprise! I was thinking you were going to use the engines on the wings in the usual way. Will they be contra-rotating?
killnoizer
First idea was the system like a jet engine, plus a housing over it i think that is all the same direction ?   But with a cover you cant see the blades ...
And i found no way to build a good housing .
So i came to this ,  and i believe contra rotating is the right way  , what do you think ?
                     ~ π ~
The various versions of the B-17 also had a Boeing factory Model 299 codes:
299B (YB-17, Y1B-17)
299F (Y1B-17A)
299M (B-17B, originally designated 299E)
299H (B-17C, B-17D)
299-O (B-17E/F/G, also shown as 299O)
299-Z (Two aircraft converted as testbeds, also shown as 299Z)
299AB (TWA B-17G conversion)
Perhaps Model 299XCD.  ;)
killnoizer
Thank you,  good idea with the test number .
Yesterday night i spend some hours more and started the blades. They need around 75 cm of cutted and shaped material (  30" )  .
I made the first step with a toaster , a bottle and a cardboard , than cut it in 8 mm lines and pre shaped the edges with a knife ,  went okay.
                     ~ π ~
Impressive conversion work there - I think I would have given up and filled and sanded all the rivets off.
I agree, there's nothing like a good, sharp file. <_<
And thank you for the Toaster idea - much, much easier and safer than using other sources of heat for softening plastic for moulding!  :thumbsup:
Quote from: killnoizer on January 25, 2024, 09:36:17 PMSo i came to this ,  and i believe contra rotating is the right way  , what do you think ?
Most certainly, this is looking amazing  :bow:
Quote from: NARSES2 on January 26, 2024, 06:02:24 AM
I'll second that
loupgarou
Impressve work indeed. And the tail propellers caught me absolutely off-guard. I would never have thought of this.
Yeah, I thought initially that it was a conventional (?!) rear-winged-but-still-Radial-powered-thingy.
killnoizer
Under construction !
                     ~ π ~
Looks like you are building a jet engine! Cool!
