avatar_seadude
STAR TREK Galaxy class starship as a passenger/cruise liner?
Started by seadude, December 19, 2023, 11:38:27 AM
Quote from: Nick on December 20, 2023, 07:26:16 AMIn one of the Mirror episodes of ST:TNG they explain that the ship is now carrying hundreds of soldiers to an outpost for a war instead of a few crew with their families. This suggests that room can be found for more people with some remodelling of the interior.
the Enterprise-D has a normal crew complement of ~1000 and has room for thousands of passengers (5000?).
Transparent roof panels wouldn't do much for the passengers, not much to see at warp and if under
impulse power the stars too far apart to see much
of anything, unless you're within a solar system. Space is mindnumbingly vast.
Viewing screens on walls and ceiling would be more
logical. That way close-ups of interesting things seen
along the way could be shown.
Unllke the Enterprise NCC-1701 (as seen in The Original Series) the Enterprise NCC-1701D had windows that you get to see on the screen.  You see them in Picard's ready room, in the cabins of the more senior crew (rank still has its privilege), and in Ten Forward (the bar situated on deck ten at the front of the saucer section).
They don't seem to have any form of window covering which i think is something i'd require rather than having all that black nothingness out there looking in at me.
Quote from: zenrat on December 22, 2023, 03:19:13 AMUnllke the Enterprise NCC-1701 (as seen in The Original Series) the Enterprise NCC-1701D had windows that you get to see on the screen.  You see them in Picard's ready room, in the cabins of the more senior crew (rank still has its privilege), and in Ten Forward (the bar situated on deck ten at the front of the saucer section).
Smart materials as part of the transparent aluminum matrix?  Much like Transitions (tm) type lenses, but on a larger scale.  Along with UV and radiation blocking properties.
As for why we never see it in the shows...it just doesn't look "cool".  Except at the beginning of Star Trek 2009, when they polarized the viewscreen
Unless those stars are extremely bright you wouldn't see much in room lighting anyway. Just like in our houses, if the lights are on inside it's pretty hard to see anything outside. If you turn the lights off then you can see stuff outside. But then you can't have guests falling down in the dark so not much point in even having windows. Maybe a viewing deck like a planetarium.
There is more than one reference to a 'Promenade Deck' in the series/books/comics, so why not a number of them, or a really enlarged version of the existing? A ring-shaped one all around the circumference of one deck maybe?
And with screen technology, why not have large windows anyway, that way you could see views of planets you're orbiting, nebulae, etc and they can always be used as massive viewscreens if the occasion demands it.
Depends what the passengers' desires/priorities are, but you could have a number of Arboreta on board.
There again, a few holodecks could fill that niche, too.
WRT enlarging the saucer hull, have you seen the pics of shipyards enlarging or modernising cruise ships?
- cut the superstructure off
- cut the hull in half, into forward/aft sections
- insert a new chunk in, to lengthen the hull
- insert half a dozen new decks-worth of superstructure
- reattach the old superstructure on top.
Bingo, you've doubled the size of the vessel, for a fraction of the co$t of a new one.
Something similar is easily doable for a saucer section.Too much mass for the existing Engineering hull? Strengthen the Shielding/Structural Integrity Fields and/or add another Warp Nacelle (or two) and Bob's Your Uncle!
...and boost the inertial dampeners, and ramp up the Heisenberg compensators.
I love Star Trek technobabble with its names rooted in real science.
Quote from: zenrat on January 05, 2024, 01:49:10 AM...and boost the inertial dampeners, and ramp up the Heisenberg compensators.
True, I had forgotten them... not a good look if your paying passengers turn into red/green/mauve smears...
The scenes with Geordi and Scotty had a level of their very own.  ;D
seadude
My ship has come in. Starship, that is. ;)
Found the following in an antique store today............and it's still shrink wrapped!  :thumbsup:  Only cost me $25.
But it'll be a long time before this model gets built. Will need to do lots of planning on building it, painting, and any other modifications.
Andrew Gorman
In "The Void Captain's Tale" by Norman Spinrad, the "Floating Cultura" tag along  on starship trips for fun and to help entertain the crew and each other. It's an interesting book that I haven't read since the 1990s but still remember.
Quote from: Andrew Gorman on May 20, 2026, 05:14:38 PMIn "The Void Captain's Tale" by Norman Spinrad, the "Floating Cultura" tag along  on starship trips for fun and to help entertain the crew and each other. It's an interesting book that I haven't read since the 1990s but still remember.
Sounds pretty cool!
I would consider enlarging the saucer by stacking more decks and strengthen the pylon. Speed isn't the big issue in a cruise ship so no need in my eyes to enlarge the engines. Just my $0.02 worth. Carry on, I say!
Diamondback
Given how much crew accommodation the Galaxy has and how few are actually needed to run the ship,  I'd say no structure mod really needed aside from a few more Big Windows spaces like Ten Forward and the botanical garden.
Remember, in the Picard finale they not only ran but fought her with just bridge-crew, Dr. Crusher and LaForge down in engineering? (Same deal as the last voyage of 1701... but this time they both did the job AND brought the ship home.)
I seem to recall a box set of deck by deck plans in the '90s drawn up by Michael Okada and published by Simon & Schuster... definitely worth picking up if you want to understand the ship's inner workings. Hell,  if I knew where they were I'd offer to sell you mine...
Quote from: Diamondback on May 22, 2026, 11:35:10 AMGiven how much crew accommodation the Galaxy has and how few are actually needed to run the ship,  I'd say no structure mod really needed aside from a few more Big Windows spaces like Ten Forward and the botanical garden.
Mrs z has a set of those.  I bought them for her one xmas.
As I type we are watching the DS9 season six episode where the massed ships of the Federation attack the Cardassian fleet in an attempt to get through to Terak Nor.
It struck me that the larger Federation ships would make for better combat craft if they could swap the big saucer sections for smaller units consisting of a bridge and a sh*t  load of weapons.
seadude
I have those box set of plans. Pic shown below. And I also saved all the pics from this artists's DeviantArt gallery of the Enterprise-D. Those are truly awesome!
https://www.deviantart.com/serialkiljoi/gallery/82970500/enterprise-d-project
Joe CalPo
