Supermarine Speagle - REALLY done!
Started by PR19_Kit, August 31, 2023, 08:54:55 AM
Looks great, but I agree with Lee - contra prop.
The only ones I have are either Shackleton ones or a very large dia. thin bladed resin that Chris donated.
No Spit kits in the loft with contraprops?
Special Hobby Mk 24 and Mk 47 Seafire both include regular and contra props.
Lee says they are inaccurate, so you'd surely only want to whiff it anyway, if you had an example...
Vulcan7
Quote from: zenrat on October 12, 2023, 03:40:45 AMNo Spit kits in the loft with contraprops?
Amazingly not, I must have purloined them for other purposes, and I have over NINETY Spitfire kits of various Marks and manufacturers and ages up there too!  :o  :o
Quote from: Vostoc7 on October 12, 2023, 03:42:28 AMP for perfect  ;D :mellow:  :mellow:  :mellow:  :tornado:  :thumbsup:  :thumbsup:  :thumbsup:
What the Seventh Oriental gentleman said! :thumbsup:
perttime
Quote from: PR19_Kit on October 12, 2023, 03:16:53 AMThe only ones I have are either Shackleton ones or a very large dia. thin bladed resin that Chris donated.
How far is the Shackleton prop from fitting?
In the Real World, Shackleton props (modified???) have been used on P-51 based air racers with Griffon engines.
Quote from: perttime on October 12, 2023, 08:29:08 AMHow far is the Shackleton prop from fitting?
I'd have to find them first. I've got two Shackleton kits somewhere, but goodness knows where. :(
Quote from: PR19_Kit on October 12, 2023, 11:11:18 AM
They're probably off cavorting in the Forest, frolicking with the nymphs and fae.
That's looking much better ...it was missing something and the Peess completed it 😊
Agree with Lee. It does need contraprops.
That aside - it's simply great!  :wub:
#133
Quote from: Pellson on October 13, 2023, 04:14:08 AMAgree with Lee. It does need contraprops.
As it was an engine test-bed, I'm assuming that this is the original prop fitted before extensive trials showed that a contra-prop was required and was fitted later (Kit's second law applies)  Our Scandinavian gentleman is as usual quite correct.................It's simply great!
Quote from: Rheged on October 13, 2023, 08:23:38 AMAs it was an engine test-bed, I'm assuming that this is the original prop fitted before extensive trials showed that a contra-prop was required and was fitted later (Kit's second law applies)
EXACTLY!  ;D
The backstory mentions the awful torque problems anyway.
