avatar_frank2056
Project AESOP 1/350
Started by frank2056, July 08, 2023, 07:30:40 PM
Looks great Frank 👍..love the metallic paint work 😀
VERY impressive, and that metallic paintwork's REALLY good.  :thumbsup:
Quote from: PR19_Kit on July 22, 2023, 04:05:03 AMVERY impressive, and that metallic paintwork's REALLY good.  :thumbsup:
Totally agree with the honourable gentleman  :bow:
Quote from: frank2056 on July 21, 2023, 02:20:00 PMThe foam started to warp while I photographed this on the hot patio surface, but has since unwarped.
More likely the gravitational distortion caused by the saucers' warp engines warming up  ;)
frank2056
Thanks, guys (and Guy). Th paint is Vallejo Metallics (an acrylic) mostly aluminum/aluminium. I added a drop of blue or sepia ink to the paint in some areas. The paint is usually very smooth - I think the graininess is due to the age of the paint or the primer  (Badger gloss black acrylic)
Chris - It was strange watching the foam warping between shots! Then unwarping.
Quote from: frank2056 on July 22, 2023, 10:17:51 AMChris - It was strange watching the foam warping between shots! Then unwarping.
There's a conspiracy theory in the making there if one had a certain mindset  :angel:  ;)
Quote from: NARSES2 on July 23, 2023, 07:14:40 AM
I wonder who in here has yhat mind set Chris 🤔 😏
frank2056
I figured out the warping and sadly, it's not due to some anti-gravity effect. I cut some groves on the underside of the plate to prevent the glue I used to tick down the tarmac from warping it as it dried. The heat caused the opposite effect.
Quote from: frank2056 on July 24, 2023, 08:50:44 AMI figured out the warping and sadly, it's not due to some anti-gravity effect. I cut some groves on the underside of the plate to prevent the glue I used to tick down the tarmac from warping it as it dried. The heat caused the opposite effect.
Well at least you know  :thumbsup:  Nothing more frustrating than not being able to work out what's causing something to happen.
