avatar_seadude
1/350 scale CVN-90 USS United States Stealth Aircraft Carrier
Started by seadude, May 23, 2023, 06:38:45 AM
seadude
For those who need an "explanation" of various items and things, here's the pics again.
PFJN
Hi,
Your build looks great.  Especially the flight deck   <_<
seadude
After gluing down the island superstructure to the flight deck, I had a major problem of a gap between the bottom of the starboard side of the island superstructure and the surface of the flight deck. You can see it in the first picture below. I'm pretty sure I explained and showed this issue before in posts long ago in this thread. No matter what I did when building the island superstructure in the past, I wasn't able to successfully correct this issue.
So my options are to either add a large or skinnier piece of styrene strip to the side of the superstructure to cover up the gap. It's the only solution I can think of.
Which looks better? A wider piece or a skinnier piece of styrene strip? And then after adding either one and painting it grey, Is there anything else I can do to the starboard side to "detail" that piece of strip or anywhere else? Any suggestions?
Steel Penguin
i would go with the larger piece, but then cut either a wavy set of scallops or  a set of lazy triangles, ( depending on your stealth style early F117 or later B2 style)  you can claim it was a letter addition that had to be added to strengthen the area due to resonance cracking, make a feature of it.   :unsure:   ;)
'Resonance cracking.'
hmmmm, that's a handy phrase to keep in mind for backstories.  :thumbsup:
Quote from: PR19_Kit on July 09, 2025, 02:47:59 PM'Resonance cracking.'
A very useful phrase that will be added to my backstory vocabulary, if I may have your permission to use it in a form of "tribute plagiarism"
Steel Penguin
go for it!  :thumbsup:
any help i can give to my peers is a good thing.
Quote from: Rheged on July 10, 2025, 08:40:55 AM
Was that what was happening to the early Typhoons when the tail would break off in flight?
Quote from: kerick on July 10, 2025, 06:50:52 PMWas that what was happening to the early Typhoons when the tail would break off in flight?
I think that was just fatigue.
Of course resonance cracking would actually produce fatigue as an end result, so I guess they're connected.
Quote from: PR19_Kit on July 11, 2025, 03:54:26 AM
Resonance causes fatigue at the nodes which results in cracking.
seadude
I think the lot of you are just "cracking" mad. Mad, I tell you!  ;D
seadude
On my carrier on the starboard side I plan to include what's called a Belknap Pole. All US aircraft carriers have these. This pole is known as the "Belknap pole", which hosts the necessary navigational lights that are usually located on masts and superstructures of normal ships. It resulted from the collision between the USS Belknap & the carrier John F. Kennedy in 1975 when the Belknap wasn't able to clearly identify the JFK's true course due to the obscurance of it's navigational lights by the whole bunch of other lights needed on and around it's flight deck.
Since I'm making a lot of structures and other parts of my carrier angled and stealthy, I figured I might as well try and make the Belknap Pole the same way if possible. The first picture below is of a concept stealthy aircraft carrier I saw on the Internet. Notice the red circled item which is the Belknap Pole on the starboard side and how it is angled inward toward the flight deck.
The rest of the pictures below show the scratch built Belknap Pole I made from spare parts.
But here's my decision: Do I leave the pole angled inward toward the catapult and jet blast deflector in the first 3 pictures?
Or do I have the pole angled backward toward the aircraft elevator instead in the last 3 pictures?
Which option do you think looks better?
OPTION # 1 BELOW:
OPTION # 2 BELOW:
