avatar_seadude
1/350 scale CVN-90 USS United States Stealth Aircraft Carrier
Started by seadude, May 23, 2023, 06:38:45 AM
seadude
Quote from: kerick on March 15, 2025, 11:03:48 PMIn the top picture the elevator parts look slightly darker but in the second picture it doesn't look that way. I'd chalk it up to the lighting. That said, a slight difference might actually show off the elevator parts to an advantage. I'd say go for it!
Quote from: Gondor on March 16, 2025, 03:26:12 AMI agree as well. Rember that the paint shade may not be exactly the same all over, the deck will take more than one tin of paint to cover in real life and it will weather as well so some variation will happen.
In the very first picture, another reason the elevator pieces may look darker is because I had to brush paint them with 2 coats whereas the larger sheet styrene piece was only spray painted once.
seadude
And the painting of the aircraft has begun. Just started on some of them tonight. Picture below. I'm starting with painting the landing gear first as that is white. As any modeler should know, it is easier to paint a darker color over a lighter color than vice versa. You paint all your light colors first, then start on your darker colors.
As for what colors I am using on all my aircraft, I did some research and came up with the following. Can't say for sure if it's accurate or not.
And I'm using all Vallejo Model Air Color paints as that is my main paint brand I now use for modeling.
F-35C    71.280 Camouflage Gray
F-18E    71.120 Dark Ghost Grey top and 70.615 Light Ghost Gray bottom.
F-18F    Same as F-18E.
EA-18G    Same as F-18E.
X-47B    71.275 Medium Gray
E-2C     71.121 Light Gull Gray top (?) and White bottom.
CMV-22B     White top and 71.121 Light Gull Gray bottom (?)
MH-60R/S    Upper 71.120 Dark Ghost Gray overall and 71.276 USAF Light Gray underside
MQ-25         Haven't selected color yet.
seadude
Starting to do major work on painting the aircraft the last several days. The F-35C's are done except for putting decals on them.
I'll probably wait until ALL aircraft for my carrier are fully painted, then work on decaling them. Makes better sense that way.  :thumbsup:
Anyway, now I'm starting to work on the X-47B UCAV's as well as some of the F-18 fighters.
Looking pretty darn good!
I think decals on those aircraft would drive me nuts. Carry on!
seadude
Quote from: kerick on March 22, 2025, 03:51:56 PMLooking pretty darn good!
I'm only going to put the U.S. national roundels on all my aircraft.
Anything else like squadron markings or other tiny details is just too much for me to handle. Not to mention too much eye strain. x.x
After all, it is a future carrier. So it's hard to say what squadrons the planes would belong to 20 or more years from now.
Can't put squadron markings on if I don't know what will and won't exist in the future?
Then again.............anybody got a spare TARDIS I can borrow?  ;D
Quote from: seadude on March 22, 2025, 04:10:29 PMThen again.............anybody got a spare TARDIS I can borrow?  ;D
Dizzy must have one, he often manages to post pics of his finished builds before the GB has even started! Or it seems like that anyway.  ;D  ;)
Totaly agree with both statements  :thumbsup:  Mind you thinking about transfers in 1/350 is enough to drive me nuts  ;D
seadude
And the painting for the X-47B's is done. Next on the list of aircraft to paint will be the F/A-18F's and EA-18G's.
The folded wings on the five X-47's are supposed to be canted more inward. But I wasn't able to do it. So what you see is what I got.
seadude
And another batch of aircraft is done tonight as far as painting goes.
I wish I had four more F-18F aircraft, but I don't right now. Not sure yet if I will buy more.
seadude
Six EA-18G Growlers are done being painted. Decals will be added later.
Next up on the To Do list will be at least 10-11 regular F/A-18E single seat fighter aircraft.
After that, then maybe I'll start on the SH-60 helicopters.
seadude
And another batch of aircraft is done being painted. As usual, decals will be added later. After these fighters, I'll start on the SH-60 helicopters next.
Can't say I'm thrilled with these Trumpeter F/A-18E's. They're nowhere near as detailed as the previous batches of Trumpeter F-18's I painted.
The previous batches of F-18's were made from clear plastic by Trumpeter and were better detailed. But these F/A-18E's which I now finished are older boxes of planes that were produced from gray plastic and lack detail. Wish I could afford better looking 3D printed planes, but they're too expensive.
seadude
UPDATE:
Currently working on the 8-10 SH-60 helicopters right now, but progress is slow. Been using a black ink pen to color the windows, but it appears the 3 special ink pens I have might be running dry. And I can't pick up new ones till I get my tax refund. And speaking of tax refund, I ran into a problem with that. So I may (or may not) get it in another 3-4 (or more?) weeks.  :banghead:  So getting a tilly crane vehicle and also the MQ-25 refueling aircraft will also have to wait.
I may temporarily start on the V-22 Osprey's and E-2C Hawkeyes next, but I'm not sure. The Ospreys are a problem because the landing gear/wheel parts are so small, I'm not sure if I'll be able to add them to the aircraft without losing the damn things.  :banghead:
Or maybe I'll temporarily start on assembling and painting all the flight deck vehicles. That should be fun.........NOT! White and yellow colors are the hardest to paint.  :banghead:
And to top everything off, I've been suffering with a cold for the last 9 days.  :banghead:  God I hate getting sick!
seadude
And the helicopters are done except for decals which will be added later.
I probably should have added the decals before adding the rotor blades but...........I guess I'm just a sucker for punishment. I like doing things the hard way.  ;D
Next on the To Do list will probably be the E-2C Hawkeye aircraft.
