avatar_zenrat
SU-76c. Finished pics pg 7.
Started by zenrat, April 14, 2023, 04:03:14 AM
Funny thing is the Ukrainians captured so many T-62s they turning them all into ARVs because they don't have enough recovery vehicles.
The 62 is so outdated that even the Ukrainians are just like " Nope to old..ain't fighting with them "  ;D
Or ditch the turret and build something you can fire javelin and tow missiles from.
Quote from: kerick on April 20, 2023, 07:03:06 PMGotta hand it to the Ukraine troops to put these things back together and try to fight with them.
I guess a second-(or third-)string tank is better than none at all.
If nothing else, it attracts fire away from other targets...  ;)
And the Israelis have proven that the older tanks can be upgraded to a pretty useful level- though they did have the advantages of experience in that sort of thing and the time to sort the designs out and get them implemented.
Quote from: Wardukw-NZ on April 20, 2023, 08:51:02 PMFunny thing is the Ukrainians captured so many T-62s they turning them all into ARVs because they don't have enough recovery vehicles.
Yeah; Vlod and his Tractor can't be everywhere...  ;D
Quote from: Rick Lowe on April 20, 2023, 10:22:28 PM
Well when a country opposite yours keeps giving you dozens of free tanks without them intending to you may as well make use of them ..it would be rude not to . ;)
  ;D  ;D
Scarey when ya think just how ture that is  :lol:
There's a good conversion project in that!
Quote from: kerick on April 21, 2023, 10:40:10 AM
Good point ..it would probably be a rather simple one as im guessing these would be more like tow trucks than full on ARVs .
A purpose built ARV is a rather complicated machine.
Quote from: Wardukw-NZ on April 21, 2023, 01:07:16 PM
Maybe some storage boxes for tools and parts. A big fat winch might be useful. Probably regional or even local production so made out of whatever is handy. Each one different.
Quote from: kerick on April 21, 2023, 04:24:04 PM
If they build em for just recovering broken down machines then yeah some storage boxes and extra tow cables .
Mounting a winch us a whole different kettle of fish..it's a ton of installing a winch ..hydraulic systems have to be installed..winch controls..cable guides..strengthening the tanks hull plus a blade mounted to the front to work as a anchor when winching .
Quote from: Wardukw-NZ on April 21, 2023, 04:31:20 PM
Just thinking of when they might have to recover a vehicle stuck in mud when the tank itself can't pull it out. Could be Russian or one of their own. Of course, you have a point thinking of old Russian built tanks the hull might just pull apart.
Quote from: kerick on April 21, 2023, 08:46:18 PM
No thinking really mate ..Indian armed forces used T-55s and T-72s and were constantly having to reweld parts on the hulls ..inside and out..they'd get cracks near where the suspension arms are mounted ...so yeah I could see them having problems with a T-62 mounting a winch with a 80+ton pulling capacity.
Scratchbuilding on this today.  Cutting some odd shaped pieces to fill the remaining gaps between the resin casement and the hull.
This is coming along.  The conversion set included PE strips to cover the seam between the new casement and the hull.  I have added these and put primer over the top.
Gun mount and gun is glued on.  If no more PSR is required then on with the fiddly detaily bits and wheels and tracks and so on and so forth.
