Boeing B-54B, the Half-Way Bomber
Started by PR19_Kit, March 06, 2023, 07:00:16 AM
And spare runner, too. At least using that, the trenches you have to fill are obvious without a coat of paint...  :banghead:
Coming along well, Kit - hoping to see it finished as and when.  :thumbsup:
Various posts on the X-13 and XF-85 have been moved to the new threads.
Quote from: Old Wombat on April 28, 2023, 08:10:18 AMAh, now I understand! :thumbsup:
Yup, apologies but the site has a rather "messy" way of moving posts from one thread to another I'm afraid and it was a bit beyond me given the number that needed shifting. This was the easiest way for me to deal with it, and it still took a couple of hours  :-\
Spino
@PR19_Kit there's probably a good reason why you don't see turboprops on pylons.  We are probably all familiar with how dangerous the Avia S.199s with the HE-111 engines were.  What made them so dangerous was the large, wide prop blades combined with a very bad gear ratio for a single engine aircraft - this created an enormous amount of torque and made the plane prone to flipping over on takeoff if the throttle was advanced too quickly.  I imagine that turboprops would impose a potentially dangerous amount of torque on the pylon if they were so mounted, though that would be negated by having stacked contra-rotating props like this build does.  Something about it just doesn't seem quite right though, but that may just be me.
Regards, Spino
What if modeling, flight sim and 3D printing enthusiast
Link to my 3D-printed model accessories (all files are free): https://www.thingiverse.com/spinoee/designs
Heavens yes, that's why I've kept the contraprops from the Bear as part of the build.
Or I will do when I get back to it.  ;D
Kit it's the contraprops which are really going to set this off..normal propellers I think wouldn't cut it for looks..when ya get back to it that is  :wacko:  :angel:
Just make the landing gear taller ;D
Quote from: McColm on May 02, 2023, 03:58:03 AMJust make the landing gear taller ;D
The main legs can stay as they are as I can position their upper anchorage point to almost any height in the fuselage.
At least I THINK I can anyway, I've not actually cut plastic on that front as yet............  :-\
Hi PR19_Kit ,
The Boeing Model 464-25 is worth studying as it looks uncannily like your build. I would recommend the 'Boeing B-47 Stratrojet and B-52 Stratofortress: Origins and Evolution, book written by Scott Lowther.
I paid £27 for my copy.
I think that's the one that ended up as the B-55 proposal., but there were so many of them!
There's more than seven different concepts for the B-55, the delta wing looks very similar to the Grumman A-12 Avenger design.
After a two YEAR hiatus on this project I took a look at it, or rather 'them' as there's two LARGE kit boxes of course. I've a mind to get back on this during the summer but there's one rather fundamental problem, I can't find the fuselage.................  :banghead:
You may well ask how the HELL could I lose something that big, but you have no idea quite how chaotic this house is. I've found the two kit boxes, with the wings in the Tu-95 box and the nose and tail in the B-29 box, but the middle bit of the Tu-95 is nowhere to be seen. Perhaps it's doing double duty as a door-prop or something...........  :-\
Draft excluder sausage, maybe? Check at the front door...  ;D
Quote from: PR19_Kit on April 23, 2023, 08:45:21 AMBecause this is meant to be a half-way house to the proposed B-55, I plan to hang the four turbo-props on pylons, as was intended for the XB-55 as well.
I can't find a single other design with turbo-props hung on nacelles like this, does anyone know of another one?
Here's the proposed XB-55.
Pylon mounted turboprops were proposed for a production version of the B-60.You cannot view this attachment.
