avatar_Old Wombat
Re: Airvell 1/72 Avro Winchester B.I/B.III
Started by Old Wombat, February 14, 2023, 04:34:16 PM
Oh, by the way, I realised that the vertical tail was as close to perfectly aligned to the horizontal tail plane as I was able to achieve, it was just that the starboard horizontal tail plane had drooped a couple of mm out of alignment. :banghead:
All fixed now! :thumbsup:
Now, I'm just fixing a couple of minor "slippages" in the bomb bay before I move onto the next stage - which I haven't decided on, yet. Decisions! Decisions! :rolleyes:
Cleaned up the fuselage seam lines last night (a product more of my ham-fistedness than any fault of the kit's).
Tonight I'm re-scribing panel lines on the engine nacelles &, as expected, I have some stuff-ups to fix (one day I'll learn how to keep my scribing tool on the straight-&-narrow ... Maybe. :rolleyes: )
Re-scribing continues slowly.
This means: When I've had enough I walk away to do something else until I feel ready to have another go at it.
Saves further big(gish) stuff-ups.
By the way, I've noticed that I may have been Matchbox's "Phantom Trench Digger" in a previous incarnation. :-\
That's a good policy.  It's one I apply to rigging the Sea Witch.  Trouble is I don't walk back often enough and its taking forever.    :-\
Just spent a decent 90 minutes spraying a whole bunch of parts & bits Tamiya XF-69 NATO Black (standing in for British Interior Black) before I start putting them together (bomb bay, wheel wells, gun turrets, etc.).
There will need to be some work done with various metallics before I get to the construction phase but the black is a good start ... & I feel like I'm making progress. (Which is always a good thing! :thumbsup: )
Quote from: Old Wombat on March 12, 2023, 04:45:13 AM. & I feel like I'm making progress. (Which is always a good thing! :thumbsup: )
Certainly is, and I'm not, but I've some reasonable reasons for not doing so.
Some progress is better than none at all so great  ;D
Now I can't wait to see more progress  :wacko:  ;D
Well, I've managed to spray 3 different types of silver onto various small undercarriage & engine intake bits, now I need to fix up some of the black bits. :thumbsup:
And tonight I've managed to mask the silver bits, so I can re-spray the black bits of the landing gear, & I'm going to use a different black, to give a bit of variation to the blacks in the wheel wells.
Speaking of the wheel wells, I've also built them & fitted the nacelles. There's going to be more PSR here than I was hoping for but, hopefully, not too much, plus some re-spraying of the NATO Black on the inside of the wheel wells.
Things seem to be going moderately well, touch wood ... LOTS of wood! :angel:
A lot less PSR than expected! :thumbsup:
Just sprayed some black into the wheel wells & around the Putty-Sand area & there is only a little "r" to finish it off, & that is really only a touch more "s".
After that I need to get the turrets in, & the cockpit glazing on, so I can start the camo. This is a problem as it would be easier to paint the plane without the turrets. However, if I do that, there are parts that need to be fitted after the turrets are in to secure them in place & these, I'm sure, will need a certain amount of PSR to get to fit properly.
Plus all that masking! :blink:
Plus the turrets need a bucket-load of work to get them ready to fit because, of course, I'm modifying them, aren't I. :rolleyes:
Quote from: Old Wombat on March 15, 2023, 08:31:11 AMA lot less PSR than expected! :thumbsup:
Favors...we do ourselves none of those  ;D
It's the best way to do what we do . :thumbsup:
